Indigo 0.9 test 8
Indigo 0.9 test 8
32 bit:
http://www.indigorenderer.com/joomla/in ... &Itemid=62
64 bit:
changelog:
* added some camera parameter checks with exception throwing if incorrect.
* added correct external IOR for phong.
* New translucent / glossy transparent code
* Changed some sampling stuff, especially for phong materials.
* added metadata writing to pngs.
* added metadata reading from pngs with --dumpmetadata switch.
* added optional watermarking with indigo logo - added 'watermark' option in inifile and renderer_settings xml tag.
* fixed path weighting bug introduced in test 7
EDIT:
Please tell me about any bugs or issues you see!
If there aren't any show-stopping bugs then this will be released as 0.9 stable.
64 bit:
changelog:
EDIT:
Aha! Thanks jurasek!jurasek wrote:Whaat watch your saved image...
greetz,
jur
A quick comparison of the new version with the old. Same material settings. This is the SkIndigo frosted glass preset. Looks SO much better!
EDIT: added normal Specular glass for additional comparison.
- Specular glass
- glass.png (97.42 KiB) Viewed 23884 times
- old versions
- Frosted Glass 09t7.png (93.7 KiB) Viewed 23888 times
- version 0.9test8
- Frosted Glass 09t8.jpg (51.3 KiB) Viewed 23887 times
great - I just took my Humanoid model with SSS skin to over 2000+ samples already in test 7
Ono - does that path weight fix alters the render of lights/caustics behind glass etc?
I'll post some skin results soon with some settings.CoolColJ wrote:great - I just took my Humaoid model with SSS skin to over 2000+ samples already in test 7
Yeah, hopefully it should fix those issues you were seeing.
- Phr0stByte
