I made small mesh in topmod (105k poly after smoothing) and I tried to export with OBJ option (fixed or non fixed mesh)
but I got this message:
-- Error occurred in main_loop(); filename: C:\Program Files\Autodesk\3dsMax8\scripts\Maxigo\Maxigo.mse; position: 111161
-- Defined in encrypted script
-- called in btn_export.pressed(); filename: C:\Program Files\Autodesk\3dsMax8\scripts\Maxigo\Maxigo.mse; position: 140770
>> MAXScript Rollout Handler Exception: -- Type error: ShellLaunch [Path and Filename] [Parameters] requires String, got: undefined <<
I've got only working xml option which you know is slow and memory-expensive...
3dsmax8, indigo stable + maxigo 0.83
I have also increased max maxscript memory usage above 100-150mb (if it matters)
What do you think about it?
PS. Is it right to have all the time showed message "Geometry Exzport Recomended"?
