MATERIAL PROBLEM IN MAXIGO 0.8.3
I do a simple scene , but Indigo don't render any material...why?
see the image
filippo
see the image
filippo
- error
- Untitled-frame-0000.JPG (239.91 KiB) Viewed 3261 times
Can you upload the scene file please?
[edit] I mean your 3ds max scene file.
I did some test and it works fine here. Strange.
Does anyone else has this problem?
[edit2]
Hey filippo, are those spheres instanced? If yes, then different materials are not supported for instanced models in Maxigo (at least not yet). All instances will have the same material as the parent model had.
Use copies instead.
[edit2]
Use copies instead.
when I turn off the enviroment and I turn on the sun-sky sistem, Indigo "saw" the material..
but I have a incorrect result..
why..?
the scene
http://d.turboupload.com/d/1802736/test_max.rar.html
why..?
the scene
- error whit sky and sun
- Untitled-frame-0000.png (642.65 KiB) Viewed 3219 times
