would this be at all useful...
14 posts • Page 1 of 1
dougal2
Post by dougal2 » Thu May 03, 2007 7:35 am
Kosmokrator
Post by Kosmokrator » Thu May 03, 2007 7:43 am
:shock: :shock: VERY VERY WELL DESIGN GUI!i like it a lot.....
SmartDen
Post by SmartDen » Thu May 03, 2007 7:46 am
Very good, i like the tabs! And i find the histogram is very useful
Kosmokrator
Post by Kosmokrator » Thu May 03, 2007 7:53 am
about the histogram....i dont understand the use of this graph...?
dougal2
Post by dougal2 » Thu May 03, 2007 8:03 am
Kosmokrator wrote:about the histogram....i dont understand the use of this graph...?
It shows the distribution of luminance in the image. In the example, it is showing that the vast majority of the image consists of pixels that are fairly dark.
To the left of the histogram is dark values, and to the right is light values.
Kosmokrator
Post by Kosmokrator » Thu May 03, 2007 8:07 am
hhmmm ok i understand but i dont see how this can help for image calibration....anyway i think may this visual represent may help somehow! :wink:
dougal2
Post by dougal2 » Thu May 03, 2007 8:10 am
it'll show up if you're clipping your whites :)
more info: http://www.cambridgeincolour.com/tutori ... grams2.htm
Kosmokrator
Post by Kosmokrator » Thu May 03, 2007 8:22 am
:) ok now i understand!thnx man!
mrCarnivore
Post by mrCarnivore » Thu May 03, 2007 7:27 pm
Nice solution of the space issue with tabs!
The histogram is a nice addition but only in combination with the tonemapping settings, imho. All the other settings only affect the histogram slightly. Also the histogram can be made much, much smaller! I think 150 x 75 pixels or so should be enough to get all the information you need from the histogram.
I would suggest you place the histogram directly in the tonemapping tab. If it's that small it should fit nicely.
dougal2
Post by dougal2 » Fri May 04, 2007 1:14 am
yup that window was just a quick test - it wasn't even displaying the correct luminosity - but having it on the tonemapping tab is a great idea.
dougal2
Post by dougal2 » Fri May 04, 2007 7:29 am
this is cool... with auto-update enabled, the histogram updates as you move the sliders. It's cool to watch! :)
carbon
Post by carbon » Fri May 04, 2007 12:35 pm
histogram should have width 256 px - 0-255, and would be VERY VERY nice to have RGB chanels
mrCarnivore
Post by mrCarnivore » Fri May 04, 2007 7:41 pm
Doesn't necessarily have to be 256 pix wide. The single values are not that important. The overall form is much more important.
Nice position for the hist. You should change to colour to black/white though!
I see no need for having a seperate histogram for each colour.
But if you did, you can use the corresponding colour for the hist colour. Then you could display them all at once with mixing the colours. Might lead to a very colourful information display that is totally unreadable, though.
dougal2
Post by dougal2 » Sat May 05, 2007 4:36 am
we could have a set of radio buttons for the histogram type:
o Red
o Green
o Blue
o Luminosity ( = 0.33R + 0.56G + 0.11R)
changing the colour to white is an easy one (or, perhaps 50% grey ;) ).
Other things that I'll show you lot soon include:
a couple of denoising filters, and the return of linear tonemapping.
