Latest Build
Latest Build
EDIT:
Latest official build will now be in the download section, use the menus at the top of the Indigo page to access the download section.
Revision 12:
last change was some stuff Dougal did, see
http://www2.indigorenderer.com/joomla/f ... php?t=1775
Revision 12:
- IndigoToneMapper.zip
- (558.32 KiB) Downloaded 560 times
Man ... the glare feature is wonderful ono!!!
Here are some suggestion for violet:
- a scroll bar (if you haven't set the screen resolution high enough some options are clipped)
- better use of space (those buttons and sliders use much more space then they actually need)
- icon for violet
- shouldn't the word "violet" be included into the window title?
- change order (tonemapping first, then whitepoint - bloom - glare - chr. abb.)
- include IGIMerge
- keep up the good work guys!
- icon for violet
- include IGIMerge
I'm still fiddling a bit with the GUI layout - that stuff is easy. although the space below the chrom.abberation slider is a bit of a mystery :Smanitwo wrote:Man ... the glare feature is wonderful ono!!!
- icon for violet
- include IGIMerge
As for including IGIMerge, I'd have to start really trying to understand how the image data is handled and stored in memory. It's not impossible but it'll take me longer to get my head around it.
(IGIMerge internally has no concept of an image as such - it just iterates through a list of numbers and multiply/adds them to the output.)
at the end of play today, i have the following (see screenshot)
* added IGIMerge. this was far easier than I expected.
* further GUI refinements. I did change around the order of the panels but I also found out why they were in the original order - that was the order in which Violet applies the processing to the image.
* removed the log window and sent all messages to the status bar.
I'm not going to post another patch just yet, we'll see if there's anything else that can be done first.
- violet-dougalpatch2.jpg (86.94 KiB) Viewed 10646 times
mrCarnivore
- joegiampaoli
Wow.
