.:: Colored glass with bitmaps
tizxx
Post by tizxx » Thu Apr 19, 2007 12:29 am
Hi to all again...
Suvakas how can I make a colored transparent glass using a bitmap as colors... with your exporter for 3ds max?
probably Indigo don't have this option...
Post by suvakas » Thu Apr 19, 2007 12:45 am
You're right.
Indigo doesn't support this yet.
Suvakas
Post by Kram1032 » Thu Apr 19, 2007 12:55 am
I think, as long as it's not SSS, it should work...
or was there an other trick behind the frogs in "they have the power"?
Post by suvakas » Thu Apr 19, 2007 2:15 am
Kram1032 wrote:I think, as long as it's not SSS, it should work...
Really? hmm
Can someone confirm if it works or not?
Post by Kram1032 » Thu Apr 19, 2007 2:20 am
ah and Kosmokrator once did a fish-bowl with transparent colourmapped fish... (or?)
Edit:
http://www2.indigorenderer.com/joomla/i ... ewsIndex=1 - they have the power
http://www2.indigorenderer.com/joomla/i ... ewsIndex=1 - exotic fish
Post by suvakas » Thu Apr 19, 2007 2:48 am
As far as i know, then the color of the glass material comes from absorption. I can't find any xml syntax for using bitmap texture for absorption?
Or can you use regular albedo texture?
ps. Those fishes aren't transparent at all.
Post by Kram1032 » Thu Apr 19, 2007 3:09 am
they are ;)
look at the top fin of the yellow fish.
It even looks like SSS, a bit, but the rays are passing linear.
I guess, it's Albedo ;)
dunno, how/why it works, but both renders show THAT it works.
Ask Kosmokrator and enricocerica!
although, when I look at the frogs, I'm not 100% sure, if they're transparent...
the fish definately are, though ;)
Post by suvakas » Thu Apr 19, 2007 3:44 am
Kram1032 wrote: although, when I look at the frogs, I'm not 100% sure, if they're transparent...
Oh, i see. I thought you were referring to the stamp on the light bulb and not the frogs :lol:
I belive the fish image was exported with Maxigo and there is no way to do it in Max at the moment.
Here is the thread: http://www2.indigorenderer.com/joomla/f ... light=fish
Fishes have Phong material.
Post by Kram1032 » Thu Apr 19, 2007 3:51 am
hmmm....
strange.
But it looks like transparent, though
Kosmokrator
Post by Kosmokrator » Thu Apr 19, 2007 4:31 am
no kram1032...its phong material looks like semi transp but is not....:)
Post by Kram1032 » Thu Apr 19, 2007 5:13 am
but there is one way to get such effects - partly at least :D
a blend
Kosmokrator
Post by Kosmokrator » Fri Apr 20, 2007 9:02 am
i dont know...maybe...but the curent indigo max exporter dont support the blend type mat... :wink:
Post by Kram1032 » Fri Apr 20, 2007 9:40 am
aha.
I didn't know that. Then, you have to wait...
Post by suvakas » Fri Apr 20, 2007 6:36 pm
Kosmokrator wrote:i dont know...maybe...but the curent indigo max exporter dont support the blend type mat... :wink:
Ok. Now i get it - hey Kosmo, you're the one who doesn't like readme's right? :lol:
Blend material is supported long long time already using standard max blend material.
Taken from readme::wink:
* Use standart Max Blend material for Indigo Blend material.
And actually Maxigo has even a user friendly approach for blend maps allowing you to use alpha map directly from Phong and Diffuse map. Alpha map actually is a blend map too.
So.. Blend maps = supported 8)
Suvakas
Ps. There also will be a separate Indigo Blend material type in next version that supports exporting the entire blend tree into *.igm file, but for now use the standard max Blend material...
Kosmokrator
Post by Kosmokrator » Fri Apr 20, 2007 8:23 pm
hahahaha damn.....:) yeap suv i dont read the damn txt....thnx!great work man!
:!: 8)
