diffused light - light cone with diffuse filter
11 posts • Page 1 of 1
F.ip2
Post by F.ip2 » Fri Mar 16, 2007 5:08 am
Hi
how would you create a light box with a diffused light so it casts only very soft shadows???
I have an issue rebuilding this - to scatter the light ray directions.
claas
Artist : Designer : Educator
of Ferris State University
Post by Kram1032 » Fri Mar 16, 2007 5:13 am
Maybe -it would need tons of calculation- a sphere as lightsource with an other sphere (this also can be a .sphere) arround the lightsphere: It should have an SSS-mat with 0 absorbtion, but some uniform SSS!
F.ip2
Post by F.ip2 » Fri Mar 16, 2007 5:22 am
I see, SSS, I did not think about that. technically you are right.
I made some tests with shooting lights into a light umbrella, wedge gave me the tip, but I had no big success with my results yet.
somehow i needed to crank up the light power significantly!
Post by StompinTom » Fri Mar 16, 2007 5:22 am
add cube. scale up. make it a light. done.
the larger the light source, the softer the shadows, the more diffuse the light. all the lightbox is is a very large lightsource (created by putting a flash bulb behind a diffuser so that the diffuser diffuses the light -> bigger lightsource -> softer light).
Post by Kram1032 » Fri Mar 16, 2007 5:25 am
an SSS-mat would kinda act as a diffuser, wont it? Just be aware that you'd better use specular SSS that glossytransp-SSS, as 2nd one has energy loss...
Post by CTZn » Fri Mar 16, 2007 5:32 am
Also very soft shadows mean the light source is quite wide (like an open, overcast sky). So make the light source bigger (yes a sphere can make sense, depending on the scene). Even if light is scattered at the source, light rays won't come from another point than the source itself (obviously :D), so size matters !
Post by Kram1032 » Fri Mar 16, 2007 5:37 am
*lol*
Size matters not! Judge me on my size do you?....
F.ip2
Post by F.ip2 » Fri Mar 16, 2007 2:09 pm
you guys have a size issue, ha?
Post by CTZn » Fri Mar 16, 2007 2:32 pm
Yes, in my case 1cm=1m :lol:
F.ip2
Post by F.ip2 » Fri Mar 16, 2007 3:21 pm
well I hope you don't pass out when you get an erec ah eruption ;)
Post by Kram1032 » Sat Mar 17, 2007 1:08 am
...=1µm=1m=1cm=1dm=1m=1km=1...
