Indigo Renderer 4.0.55 Beta Release
pavoda
Re: Indigo Renderer 4.0.55 Beta Release
Post by pavoda » Thu Aug 17, 2017 9:49 pm
Lal-O wrote:I have noticed that the Light Layers problem remains only by using GPU, there is no problem if i render with CPU :D... I'm not sure if the rendering method is a factor that influences the problem. (Bidir is "ok",Path Tracing "not ok" ).
Regards.
There are more different between CPU and GPU render metod, it is development...I see improvements every new version and I always look forward to it :) Light layers on Gpu is one of the last Improvement and can be expected some discrepancies...
I have also discovered one problem.
Render glass material and use alpha background.
1. Glass as specular is ok. Background behind glass is transparent
2. Glass as glossy is not ok. Background behind glass is full visible
Related problem is - If I click on glass material and change from glossy to specular (or conversely) Indigo crash.
GlassScene.pigs
(118.61 KiB) Downloaded 1426 times
Post by Zom-B » Thu Aug 17, 2017 10:20 pm
pavoda wrote:I have also discovered one problem.
Hey pavoda,
Interesting about this Glossy T. alpha issue, I'll create a ticket in the Bugtracker about it, thanks for reporting!
Regarding the crash I can not reproduce this on my GPU and CPU...
Is this maybe on GPU only? Do you use the latest drivers?
Does Indigo create a minidump on next start? can you upload it?
pavoda
Post by pavoda » Thu Aug 17, 2017 11:18 pm
Hey pavoda,
Right, it is crash only on gpu render. But.. I found, that this crash is only during using 2 gpu cards together. If I deactivate one (No matter which one) indigo doesnt crash . I tried deactivate SLI too and it is no effect.
Drivers are latest.
Minidump is not create in this case. never.
Post by Zom-B » Fri Aug 18, 2017 1:26 am
pavoda wrote:Right, it is crash only on gpu render. But.. I found, that this crash is only during using 2 gpu cards together. If I deactivate one (No matter which one) indigo doesnt crash.
Tested on MacPro with dual cards without issue, no multi GPU PC at hand atm :/
A small shout out:
If some of you guys around with a multi GPU setup could check if this is also happening to to you, that would be awesome
pavoda
Post by pavoda » Fri Aug 18, 2017 1:58 am
A small shout out:
One more finding.
When I do change material type (even diffuse to phong etc.) durring Realtime preview in C4D it crash too. Again only when using 2 Graphic cards.
burnin
Post by burnin » Fri Aug 18, 2017 4:11 am
- no crash @ default settings, using 2 GPUs (w7, Q M5000 + GTX 1060 /// driver v. 378.49)
- 2 GPUs: crashes as soon as i change Glass to Specular (or anything else), in RTP & even when rendering is paused
- 1 GPU: changing material types using one GPU (any) it works
dump file
indigo.exe.8568.dmp.7z
(4.02 MiB) Downloaded 1142 times
Originalplan®
Post by Originalplan® » Fri Aug 18, 2017 6:03 am
- no crash whatsoever on macOS
- changing mat types and rendering on both GPU's = all cool
Post by Zom-B » Fri Aug 18, 2017 10:38 am
Thanks a lot for testing burnin, after your report I organized some second GPU and tested by myself:
I can verify that for multi GPU systems Indigo crashes while changing Materials, even on the simple material sphere.
Thanks again for reporting, I'll add it to the Bugtracker!
Polinalkrimizei
Post by Polinalkrimizei » Tue Aug 22, 2017 9:56 am
Hey guys, not sure if this was reported before - there are subtle differences on how intersecting specular mats are handled in GPU and CPU mode.
The liquid and the glass are just specular mats without sss, WITH sss on it appears to be the same "problem". The liquid has a lower precedence than the glass. And may not be modeled perfectly.
On a side note: This improved much since 4.0.50, where the full bottle was rendered grey - I just updated and was actually more pleased with the results than before!
Last edited by Polinalkrimizei on Tue Aug 22, 2017 10:08 am, edited 1 time in total.
Post by Oscar J » Tue Aug 22, 2017 10:00 am
Looks like you just need to raise ray depth (under GPU settings). :)
Polinalkrimizei
Post by Polinalkrimizei » Tue Aug 22, 2017 10:09 am
Oh awesome!!
Will try that, thanks :-)
Polinalkrimizei
Post by Polinalkrimizei » Tue Aug 22, 2017 10:12 am
Seems to work :-)
This forum may seem deserted lately, but still kicks ass!
Post by Pibuz » Fri Aug 25, 2017 8:49 pm
Hi guys! There's a bug when trying to rotate an HDR during rendering Indigo freezes and exits!
Post by Oscar J » Fri Aug 25, 2017 11:05 pm
CPU or GPU?
Post by Pibuz » Fri Aug 25, 2017 11:08 pm
CPU!
