Help with network rendering
Come here for help & support.
afecelis
Post by afecelis » Sat Nov 21, 2015 1:35 pm
Hi guys,
I'm following the tut found here:
http://www.indigorenderer.com/documenta ... g-tutorial
However I haven't succeeded on getting the slave computers to "talk" to the master. My setup is as follows:
-1 manager computer: Windows 10 PC. Core I7 4770K @3.5 Ghz 32GB RAM @1600MHz
-1 network slave: Imac 27" Core I5 @3.2GHz/ 16GB RAM
-1 network slave: Macbook Pro 15.6" Retina Core I7 @2.5 GHz/ 16GB RAM
The hostname and the workgroup are properly setup on all computers. The network is communicating fine sharing files to/from each and every computer (win-to-mac /mac-to-win).
I'm attaching a screenshot of the error reported when I start the network slave. It says it failed to resolve the hostname "design02" but that's the one set everywhere. Error code=8.
Thanks in advance for any help ;)
regards,
Alvaro
Re: Help with network rendering
Post by zeitmeister » Sat Nov 21, 2015 8:16 pm
Didn't network render on mac since ages but never had this problem. Are you sure you named the slave everywhere correctly? To be sure you could also allow all permissions of the library indigo folder and indigo program folder to full access plus allow file sharing for these folders in the system sharing panel.
Cheers, zeiti
Post by Zom-B » Sat Nov 21, 2015 9:14 pm
I did network rendering without problems from my Win Master and adding some Mac slaves.
So it is possible and should work...
The Error Code 8 can be explained by the Devs best I think.
(btw dear devs: Error codes should be always explained directly in th error message as much as possible!)
afecelis
Post by afecelis » Sun Nov 22, 2015 12:57 am
Thanks for replying guys.
I'll double-check names and permissions everywhere. I agree there should be no problem setting up a render farm between different OSs. And yup, error codes should be included with Índigo's documentation.
Regards,
Alvaro
Post by OnoSendai » Sun Nov 22, 2015 4:39 am
I made a new build with a couple of changes, please try it: http://downloads.indigorenderer.com/dis ... 3.8.30.dmg
* Better error messages for DNS resolution on OS X and Linux, tweaked DNS resolution a little.
afecelis
Post by afecelis » Sun Nov 22, 2015 6:43 am
Thanks Ono! downloading and trying out right away! :D
I'll report back.
afecelis
Post by afecelis » Sun Nov 22, 2015 4:02 pm
No luck Ono :(
Here's the new log:
Executing '-n s'
Indigo Renderer v3.8.30, OS X 64-bit build.
Licence verified.
Licence type: Indigo 3.x Node.
Licensed to 'XXXXXX@gmail.com<Alvaro F. Celis>'
Waiting for a master.
While connecting to network manager: DNS Lookup failed: Failed to resolve hostname 'DESIGN02': nodename nor servname provided, or not known
Post by Headroom » Tue Dec 29, 2015 7:52 am
Did this ever get resolved ?
I've run int a similar problem.
My main machine is an iMac (OS X 10.11.2) and the two slaves are PCs with Win10.
All are connected per WiFi to a relatively new Airport Time capsule.
The slaves don't find the master and the master does not show any slaves.
I am wondering if this has to do with the fact that I am not running Indigo from an admin account on my master machine.
Post by Oscar J » Tue Dec 29, 2015 8:03 am
You need to start the network clients on the slave machines. :?:
Post by Headroom » Tue Dec 29, 2015 8:16 am
I've tried that already. Even as admin.
Post by Oscar J » Tue Dec 29, 2015 8:29 am
Any firewalls active?
Post by Headroom » Tue Dec 29, 2015 9:24 am
I have figured out part of the problem. The node licenses are Indigo version 2.xx These would need to be updated to Indigo 3.xx
At the moment it looks like that's a paid upgrade and thats not going to happen.
Post by Oscar J » Tue Dec 29, 2015 9:25 am
Shouldn't be with a lifetime license I think. I'm sure they'll sort it out for you, but I think some of the devs might be away for a few days.
Post by Headroom » Tue Dec 29, 2015 10:09 am
Hi OscarJ thanks for the help!
I am sure they could sort this out. They would not have to though if this would work ;-)
I can only see that the node version needs to be updated on the slave machine. There I can click on the only user interface element, the big blue button labeled "Upgrade to 3.0".
This brings up the browser on the slave machine with a web page that instructs me to visit my private Indigo order page. It says I can then click the "Buy Now" button in the "Upgrade to Indigo 3" section.
Ok, so I walk back to my main machine, search and find the mail agin and click on that link again.
And, indicative of the whole process, there is no "Upgrade to Indigo 3" section, thus there is no "Buy now" button. So I have to admit being a bit irritated at the moment.
Post by Headroom » Tue Dec 29, 2015 12:39 pm
Ok. Ono added 2 Indigo 3 Node Licenses, which I registered and verified.
However, I can still not see these in the network panel in Indigo on the master.
When I start he slaves I get the message as shown in the screen shot on both slave machines.
The Firewall is disabled on both slaves. I've tried to:
1. Start Indigo and start render slave, without starting the Indigo Network Client prior to that
2. "" "" with the starting the Indigo Network Client
3. "" "" with installing the Automatic Render client
I can ping both machines from the master and I can ping the master from both machines using either the local host name or the IP address.
I am by no means an beginner if it comes to networking and maintain a open source software library that allows micro-controllers to discover and service Bonjour services.
However, I have no idea about the underlying mechanisms how Indigo does it's networking. There is no code, no documentation that allows trouble shooting, and the software does not provide any appreciable level of information to diagnose the problem.
I find that very frustrating!
Slave message.PNG (9.12 KiB) Viewed 10052 times
