Blendigo 3.8.5.2
Re: Blendigo 3.8.5.2
Post by Oscar J » Sat Dec 06, 2014 3:32 am
Pretty much all features except alpha rendering for some reason.
vis4arch
Post by vis4arch » Sat Dec 06, 2014 4:31 am
Thx for the info.
have a great weekend.
all the best,
tamas
berg8 - werbeagentur
. design . web . marketing .
Post by StompinTom » Sat Dec 06, 2014 11:10 pm
Oscar J wrote:Pretty much all features except alpha rendering for some reason.
It supports alpha rendering just fine.
Post by Oscar J » Sat Dec 06, 2014 11:20 pm
Really? Where do I fin the checkbox? :shock:
Post by StompinTom » Sun Dec 07, 2014 5:12 am
Oscar J wrote:Really? Where do I fin the checkbox? :shock:
Render Settings -> Rendering Mode -> Custom
Then check BiDir, Metropolis, etc. and if you check Alpha Mask, it will render with alpha :)
vis4arch
Post by vis4arch » Wed Dec 17, 2014 8:28 pm
Hi There,
any plans or release date, when will be the indigo renderer's new scatter engine in the blender exporter plugin implemented or supported?
I think this is a must have feature.
all the best,
tamas
Post by StompinTom » Wed Dec 17, 2014 9:43 pm
@vis4arch
You can already do a hell of a lot with Blender's particle systems and group instancing. You get quite a lot of control from within Blender. Have you tried that?
vis4arch
Post by vis4arch » Wed Dec 17, 2014 11:59 pm
Hi There,
yep, i did some exterior projects with blender PS and indigo ... just the export time is ridiculously long, and the memory usage is also high.
all the best,
tamas
Post by StompinTom » Wed Dec 24, 2014 4:52 am
Quick request: For emitters, could we enable <backface_emit> from the Blendigo GUI? Really handy for things such as fire and flames... Annoying to edit the .igs file each time you export :P
FakeShamus
Post by FakeShamus » Wed Dec 24, 2014 4:58 am
+1
and a check box within Indigo's material emit settings, if you create an emitting material from scratch.
agentwd40
Possible bug
Post by agentwd40 » Sun Jan 04, 2015 8:51 pm
Blendigo is having trouble with more then 4 external materials. I have 10 poly models with linked materials. (Indigo Render material Settings - Material Type - External.) If I render out more then 4 external materials Blendigo renders everything with the same material. Less then 4 and it renders out fine. All textures and materials are in the same folder. I created the materials in Indigo. I've tried pigm and normal igm files.
- using Blender 2.72b, current Indigo, current blendigo.
doomed
Post by doomed » Wed Jan 07, 2015 3:58 pm
Check your .pigm, check Material Name property in the .pigm files, some of your pigm's may have same Material Name, so indigo replace materials with the same Material Name, I used about 20 external materials all works fine.
agentwd40
Post by agentwd40 » Fri Jan 09, 2015 3:03 pm
doomed wrote:Check your .pigm, check Material Name property in the .pigm files, some of your pigm's may have same Material Name, so indigo replace materials with the same Material Name, I used about 20 external materials all works fine.
It's my fault. I didn't have the blended layers named. Went back, renamed them and everything works.
:oops:
Users browsing this forum: Majestic-12 [Bot] and 3 guests
