Jacuzzi effect?
Pikadili89
Jacuzzi effect?
Post by Pikadili89 » Fri Dec 12, 2014 11:45 pm
Hey guys, the title says it all! :D
I need to do Spa center and ofc it needs to have jacuzzi. So my question is, how can I make or at least fake jacuzzi effect? Have anyone tried something like this before? I tried searching forums but found nothing helpfull :(
http://www.vangviet.com/wp-content/uplo ... i-pool.jpg#
This is what I want to do and curently I failed every time with displacment maps. Anyone have any idea?
Thanks in advance!
Re: Jacuzzi effect?
Post by Zom-B » Sat Dec 13, 2014 12:20 am
Yes, seems not that easy...
My approach would be:
- Use a glossy Transparent material with photo a texture of such a jacuzzi water to control the exponent of the material.
- Use the same but a little blurred texture for displacement!
- Now use the texture to control the color too.
The exponent map needs quite some strong contrasts I suggest.
SSS is maybe even not needed here :)
Re: Jacuzzi effect?
Post by OnoSendai » Sat Dec 13, 2014 12:26 am
Depending on how accurately you want to model it, you could try blending a diffuse white material with the water specular material, with a blend map that looks like the 'bubble waves'.
Re: Jacuzzi effect?
Post by CTZn » Tue Dec 16, 2014 6:42 am
hi, this is one effect I was willing to synthetise with ISL, I may be back to you soon. do not hesitate in bumping this up if I am lasting about it.
Re: Jacuzzi effect?
Post by CTZn » Fri Dec 19, 2014 3:10 am
Well, don't let me hold you back on this one, my first results were quite limited. I'll try to have them uploaded tomorrow even though I'm unhappy about them. They figure jet convection sort of, not bubbles. Crappy. Ouch :/ Tomorrow hopefully.
FakeShamus
Re: Jacuzzi effect?
Post by FakeShamus » Fri Dec 19, 2014 5:37 am
here, I thought I'd take a shot at this. it's basically Ono's suggested approach with blend of specular and diffuse.
the scale of displacement needs tweaking depending on your scene scale. plus the texture values for blend and displacement will depend a lot on the images you are going to use.
I also used one material for the top of the water cylinder (bubbly blend) and for the sides and bottom (plain water with blue-green color), those both have to share the same medium.
this would probably benefit a lot with the photon-mapping methods that are in the works too, cause the water parts take a while to clear up and are pretty dark.
anyway, something to play around with and get you started. it's a pretty cool challenge.
hot tub blend 2.pigm
(3.92 MiB) Downloaded 457 times
Re: Jacuzzi effect?
Post by OnoSendai » Fri Dec 19, 2014 5:38 am
Looking good FakeShamus!
Re: Jacuzzi effect?
Post by Zom-B » Fri Dec 19, 2014 6:32 am
awesome, up to the MatDB!
FakeShamus
Re: Jacuzzi effect?
Post by FakeShamus » Fri Dec 19, 2014 6:51 am
thanks!
here, it works much better with simple color absorption in the medium instead of absorption layer with an image texture. also made the bubbles a uniform color phong instead of image color.
hot tub blend 3.pigm
(2.19 MiB) Downloaded 485 times
FakeShamus
Re: Jacuzzi effect?
Post by FakeShamus » Fri Dec 19, 2014 7:01 am
Re: Jacuzzi effect?
Post by Oscar J » Sat Dec 20, 2014 6:41 am
Wow, awesome material! :shock:
Re: Jacuzzi effect?
Post by CTZn » Sun Dec 21, 2014 8:49 am
oh wow fakeshamus... this is one instance where I should have hold my horses back but I must now comply and post a lame thing. I meant what I said and I... grrrr :lol: good job.
The treat is, in the bump shader you can try 4x3 combinations for a result, just move the # signs around.
Jet Convection combinatory.zip
pigm
(878 Bytes) Downloaded 477 times
Pikadili89
Re: Jacuzzi effect?
Post by Pikadili89 » Sat Feb 28, 2015 12:14 am
Hello guys, first of all I want to apologise for my so late respond. During my strugle with jacuzzi effect I sudenly got a new task from my boss and I needed to pause the spa interior project. Today I finish spa interior and I decided to share with you both of my works. That suden task was interior design of catering apartment in vila, the interior was desired as light classic. And I am happy to tell you that it is accepted by investor. As for spa center, it is existing building which demands heavy reconstruction. Interior was desired to be luxorius and modern.
In this comment I am uploading catering aparment in vila, in second, I will upload spa center.
And ofcourse, I owe a big THANKS to FakeShamus for sharing this awsome material! Thank you mate! :)
c&c are welcome as always! Hope you'll enjoy! :D
bubs
Re: Jacuzzi effect?
Post by bubs » Sat Feb 28, 2015 12:25 am
Very impressive modelling and scenes! 8) Excellent work, my only comments are, the mapping for the brick on the back of the fireplace is a little off IMO (but I'm being really picky here!! :lol:) and that there is some noise, a bit longer rendering and these would be spot on! Well done! :D
Pikadili89
Re: Jacuzzi effect?
Post by Pikadili89 » Sat Feb 28, 2015 12:31 am
Spa! :D
