SkIndigo 3.8.6.1
Re: SkIndigo 3.6.8.1
Post by OnoSendai » Wed Jul 30, 2014 8:01 am
lape wrote:Component instancing does not work.
Hi lape,
In what way does it not work?
Do you only see one component instance? Does it give an error message?
lape
Post by lape » Wed Jul 30, 2014 8:10 am
I don't get an error, I only the see the component, the dummies I used for instancing just can't be seen.
24 hours isn't enough
http://www.werkraum3d.com
Post by OnoSendai » Wed Jul 30, 2014 8:11 am
I know, I should not install a beta when I have to finish a project, but now I reinstalled 3.6.28.3 and get this:
SkIndigo version: 3.6.28.3
SketchUp version: 14.1.1282
Ruby platform: i386-mingw32
Error during processing: BlendMaterialUndefined
C:/Users/Knopp/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:8533:in `write_mat'
C:/Users/Knopp/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:8282:in `export_material'
C:/Users/Knopp/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:968:in `block in export'
C:/Users/Knopp/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:967:in `each'
C:/Users/Knopp/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:967:in `export'
C:/Users/Knopp/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:11606:in `block in <top (required)>'
-e:1:in `call'
any help? :?
Regarding your error, looks like a blend material has an invalid child (material a or material b).
Post by OnoSendai » Wed Jul 30, 2014 8:12 am
lape wrote:I don't get an error, I only the see the component, the dummies I used for instancing just can't be seen.
Are you using the _dummy technique?
lape
Post by lape » Wed Jul 30, 2014 8:15 am
yes, _dummy!
I did not use a blend material, just used a hdri for environment map + add sun from sketchup. When I try tu use light layers, the error occurs.
Post by OnoSendai » Wed Jul 30, 2014 8:17 am
lape wrote:yes, _dummy!
Ok. The '_dummy' bit is case sensitive now, so it must be lower case. If you want to send me your scene I can try it out here.
Post by OnoSendai » Wed Jul 30, 2014 8:29 am
Uploaded new version, uses a different mesh cache directory, which should help prevent bad interactions with previously cached meshes from the 3.6 skindigo series.
lape
Post by lape » Wed Jul 30, 2014 8:30 am
The worst thing is that i cannot get my environment map work!
Now I am back on 3.8., and this is what happens, see attached screenshots.
Post by OnoSendai » Wed Jul 30, 2014 8:45 am
lape wrote:The worst thing is that i cannot get my environment map work!
Can you send me the .skp file?
lape
Post by lape » Wed Jul 30, 2014 8:57 am
environment test.zip
(20.3 KiB) Downloaded 302 times
here it is...
lape
Post by lape » Wed Jul 30, 2014 9:38 am
...about the instancing problem:
It only works, when the component doesn't contain other components. In my case, it is a hedge, and there are different components for leaves, branches etc. When I explode these components, and only have one major component, the dummies will work. Unfortunately this blows up my filesize.... :cry:
Post by OnoSendai » Wed Jul 30, 2014 9:39 am
lape wrote:...about the instancing problem:
Can you send me the scene via dropbox pls?
Post by OnoSendai » Wed Jul 30, 2014 9:54 am
This seems to be an issue with sun + env map with bidir enabled. Just avoid that combination for now.
lape
Post by lape » Wed Jul 30, 2014 10:16 am
No, it also doesn't work using path tracing, can't get the sun layer working while environment map is in use! And if you use camera instead of reinhard, everything turns black...
Back to 3.6 ???
Post by OnoSendai » Wed Jul 30, 2014 10:32 am
Updated build, fixed the hedge instancing.
