[BUG] motionblur with render instances...
9 posts • Page 1 of 1
Post by zeitmeister » Fri May 03, 2013 11:09 pm
... doesn't work; render instances aren't being displayed.
Scene tree:
- Null object (animated, MB-tag)
--- model
--- render instance
--- render instance
Latest Indigo, latest Indigo for C4D, C4D R14, Mac OS.
Could this be fixed? Would be awesome!
I need this to do automotive rig shots... :)
Re: [BUG] motionblur with render instances...
Post by fused » Sat May 04, 2013 2:44 am
zeitmeister wrote:... doesn't work; render instances aren't being displayed.
Scene tree:
--- model
--- render instance
--- render instance
Would it be possible to get an example scene for this specific problem?
I may have on by ZomB that shows a similar problem but it'd be good to have one that shows the exact problem you are having.
Post by zeitmeister » Sat May 04, 2013 3:35 am
Few minutes...
Post by zeitmeister » Sat May 04, 2013 3:42 am
Attached.
Just switch the instances to regular instances and it works...
it really happens only with render instances.
mb-instance_bugscene.zip
(77.62 KiB) Downloaded 456 times
Post by fused » Sat May 04, 2013 3:49 am
zeitmeister wrote:Attached.
That's so strange. Looking into it.
Post by fused » Sat May 04, 2013 3:58 am
You can just work around it by not using C4D render instances then, it doesn't make a difference for Indigo anyway.
Post by zeitmeister » Sat May 04, 2013 4:47 am
... but it does in C4d! :-))
Post by fused » Tue May 07, 2013 10:42 am
This looks a bit better doesn't it?
Still the same limitations as before (only keyframed animation, etc) but it works for render instances now.
Post by zeitmeister » Tue May 07, 2013 6:47 pm
Yeah, fantastic!
Thanks a lot!
