Blendigo 2.6.x Betas
dougal2
Post by dougal2 » Fri Oct 22, 2010 1:07 am
2.6.1
Superseded by 2.6.1.4, see below.
New in this release:
* Added save_images_on_close setting (system)
* Added glass_acceleration setting (renderer) for bidir mode
* Linux: changed installer to produce less junk output
* Linux: changed installation method to require manual indigo path setting, same as OSX
YOUR FEEDBACK IS ALWAYS APPRECIATED
As with the current efforts to get Indigo 2.6 as complete and user-friendly as possible, please please keep reporting any issues you find with Blendigo - it is your feedback as users and artists alone that push Blendigo forward into being the software that works for you.
Re: Blendigo 2.6.x Betas
Post by StompinTom » Fri Oct 22, 2010 3:31 am
Thank you thank you thank you. Off to use/test.
EDIT: Something I've always meant to ask for: would it be possible to put in environment map rotation in the Environment Tab? Would be very helpful and saves going into Photoshop and offsetting my HDRI to rotate it...
Doug Armand
Post by Doug Armand » Fri Oct 22, 2010 4:46 am
StompinTom wrote:Thank you thank you thank you. Off to use/test.
+1
Doug
Doug Armand
FakeShamus
Post by FakeShamus » Sat Oct 23, 2010 7:40 am
this works great so far.
I want to note one thing I just noticed with recent Blendigo versions (thanks to one particular scene) I just ran into a problem with blend materials in combination with external materials.
as a generic example, I have a materials "A" and "B" in blender. "B" is set to be an external material, pointing to the file "C.igm". then I create a blend material using "A" and "B". but when I export the scene, the blend material is written to the .igs as a blend of "A" and "C" and Indigo complains that there is no material "C" defined. so I have to go and change the name in the .igs. this even happens when the material name inside "C.igm" is set to "B"
so basically it looks like blendigo is choosing the external filename instead of the material name.
dougal2
Post by dougal2 » Sun Oct 24, 2010 12:16 am
FakeShamus wrote:this works great so far.
I can believe this - I can't remember if Blendigo opens up the material file to check the name, or if it assumes that the material name is the same as the file name. I will check it out and see if I can make it smarter.
Post by CTZn » Sun Oct 24, 2010 10:46 am
That's the convention:
According to the IGM specifications, the file name should be the name of the root material within, plus the igm extension.
It is a good habit to follow specs when sharing Indigo materials, because in general exporters writers try to stick to them !
dakiru
Post by dakiru » Sun Oct 31, 2010 11:41 am
Hey, dougal2,
I noted that it is not possible to define the exponent texture in Glossy Transparent material in Blendigo (2.6.1) :wink:
dougal2
Post by dougal2 » Sun Oct 31, 2010 11:57 am
dakiru wrote:Hey, dougal2,
OK, thanks, I'll investigate
dougal2
Post by dougal2 » Sat Nov 27, 2010 4:31 am
2.6.1.2
* Added exponent map support to Glossy Transparent (specular)
* Added Black/White hint to Blended material UI
* Added support for step_blend for Blended material
Post by StompinTom » Sat Nov 27, 2010 5:48 am
dougal2 wrote:2.6.1.2
DOWNLOADS
WINDOWS: []
LINUX: Coming soon
OSX: Coming soon
:D Thanks! Off to play...
Post by StompinTom » Sat Nov 27, 2010 6:28 am
Ah yes, can you add the 'glass_acceleration' toggle in the next one too?
dougal2
Post by dougal2 » Sat Nov 27, 2010 9:31 am
StompinTom wrote:Ah yes, can you add the 'glass_acceleration' toggle in the next one too?
I think it's already in there somewhere :?:
Post by StompinTom » Sat Nov 27, 2010 10:19 am
Whoops, OK, found it! Sorry :oops:
Also, had to add '#!BPY' to the first line of the script for it to register in Blender.
Still gives the error warning when I run the script, but, as usual, when I press OK it goes away and everything works well.
dougal2
Post by dougal2 » Sat Nov 27, 2010 10:55 am
ah damn, I appear to have nuked that line by accident. I'll re-add it and re-upload the releases tomorrow.
dag
Post by dag » Sat Nov 27, 2010 12:49 pm
You need autohotkey to autoclick that bitch, or you will go mad!
