Indigo Renderer 2.4.9
Re: Indigo Renderer 2.4.9
Post by pixie » Wed Aug 18, 2010 12:07 pm
Zom-B wrote:
pixie wrote:Which Bug?
Some materials cause artifacts in alpha rendering!
A quick workarround would be forcing clayrender mode (if availible in exporter) to do the alpha pass...
The other worarround is deleting all materials, starting Alpha rendering, and back in your 3D application you hit the magical STRG+Z combo.
I do it everytime that could be the reason I never spot it (the clayrender+alpha)
CoolColJ
Post by CoolColJ » Thu Aug 19, 2010 5:18 pm
Woot!
Time to dig out my pool renders again :D
Post by neo0. » Thu Aug 19, 2010 7:57 pm
It happened with textured diffuse and phong materials.
Post by OnoSendai » Thu Aug 19, 2010 8:08 pm
CoolColJ wrote:Woot!
Please do, you should see some improvement :)
Post by zeitmeister » Thu Aug 19, 2010 9:10 pm
Hey, thanks for that!
MLT really seems to be faster... wonderful!
Still small issues with the Indigo Mac GUI:
- still half-size fonts and buttons in light layers tab
- still half-size font in render log tab
Small issue in Material Editor:
- CMD+Q doesn't work to quit the program, not even over "Indigo" > "Quit Indigo"
I can't do further testings, because I'm going on a trip to Ireland with my girlfriend tomorrow.
Keep rockin, guys!
Post by CTZn » Fri Aug 20, 2010 4:43 am
fans of MLT modes will definitely want to check it out!
<very_large_smiley>
Post by Zom-B » Fri Aug 20, 2010 4:53 am
lycium wrote:* EXR saving now saves 32-bit per channel RGB images, instead of 16-bit per channel RGBA images.
* Fixed clipping of EXR values.
* Re-enabled save_untonemapped_exr
I finally tested this, and there are some issues:
1) saving from the GUI always saves a linear Tonemapped EXR, Camera Tonemapping & Reinhard settings in GUI get ignored!
2) The EXR autosave feature should also be integrated in the GUI > Options
3) The EXR version seems to have brighter highlights on reflective mats like chrome etc. Also Aliasing between strong contrast areas seems different!
(Maybe I'm wrong here, but I'll do a propper test setup for this someday later)
djegoo
Post by djegoo » Fri Aug 20, 2010 9:22 am
YO
Thanks all
this is cool.
Keep it up !
Post by StompinTom » Sat Aug 21, 2010 12:32 am
It appears to be true! My interiors are clearing up noticeably faster :D
Post by StompinTom » Thu Aug 26, 2010 5:19 am
The only problem with this is that you can't make an alpha rendering of objects with alpha-mapped materials, such as leaves, where it is especially useful for compositing a sky in behind trees.
Post by Zom-B » Thu Aug 26, 2010 7:47 am
StompinTom wrote:The only problem with this is that you can't make an alpha rendering of objects with alpha-mapped materials, such as leaves, where it is especially useful for compositing a sky in behind trees.
Yes, you are right.... Cindigos clayrender supports alpha mapped materials, emitters, bump & displacement so we are fine with this.
Anyway, its a bug inside Indigo, and also a workarround for Exporter writers to export only diffuse mats if alpha rendering chosen doesn't make any sense...
Users browsing this forum: No registered users and 200 guests
