Does Maxigo 0.9.4 work with 3d studio max 5.1 ?
4 posts • Page 1 of 1
hylt
Post by hylt » Thu Sep 27, 2007 1:56 am
Hi There
Can anyone tell me if Maxigo 0.9.4 works with 3d studio max 5.1 ?
I've set it up as per the instructions in the read me file but when I get to this part of the instructions:
* Start the script by clicking the button.
I get a Macroscript Error Exception which reads:
--Syntax error: at while, expected "do" or "collect"
--in line for theFace in faces while map/verticies. count == 0 do
there is no sign of an exporter dialog window as it says they should be.
Anybody any ideas? Or does this not work with 3ds max 5.1 ?
Kindest Regards
Hylt
Post by suvakas » Thu Sep 27, 2007 4:48 am
Hi hylt,
I have no idea. The oldest Max version Maxigo has been tested on is 6. If there were some changes in maxscript between versions 5 and 6, then yeah, it may not work on 5.
hylt
Post by hylt » Thu Sep 27, 2007 5:05 am
Hi Suvakas
I don't know if there is any changes between max 5 and max 6, but I guess as it doesn't seem to work the answer maybe yes.
It's a shame as I was looking forward to using Indigo with max, looks like I may go the blender route unless I can find another exporter.
Thanks for the help anyway.
Kindest Regards
hylt
afecelis
Post by afecelis » Fri Sep 28, 2007 1:21 am
Maxscript's syntax changed radically (as Suvakas says) from max5 to max6, so yep, the lowest version maxigo works with is 3ds max 6.
