Indigo Crashing when trying to render own scene
12 posts • Page 1 of 1
gu3st
Post by gu3st » Thu Mar 08, 2007 5:34 pm
Well, I can have indigo render the scenes that come with it, but when I export scenes from 3dsmax, Indigo crashes.
Any Help?
Post by OnoSendai » Thu Mar 08, 2007 8:20 pm
What's the error message that it's giving?
Post by suvakas » Thu Mar 08, 2007 9:04 pm
...and what versions of Indigo and Max exporter you are using?
Suvakas
gu3st
Post by gu3st » Fri Mar 09, 2007 10:27 am
It gives a standard XP "Indigo has encountered an error and had to close". I'm using Indigo 0.6, 3dsmax 8, and Max2Indigo 616.
If the dump that it gives off would be helpful (To developers), I can get that also.
Post by suvakas » Fri Mar 09, 2007 7:22 pm
2 most common reasons for crash:
You must have at least one light source in your scene (either mesh light or sun light).
If using sun (direct light or sun system), then be sure that the sky is enabled on exporter dialog too.
Suvakas
gu3st
Post by gu3st » Sat Mar 10, 2007 2:09 am
I am using a light source in my scene.
Post by suvakas » Sat Mar 10, 2007 2:26 am
What's in your scene then?
Can you render a simple plane + sphere + sun?
You are not very generous with info :wink:
Suvakas
gu3st
Post by gu3st » Sat Mar 10, 2007 4:01 am
All I have in my scene is a simple box created with inward facing planes, a prism with Indigo Glass on it, and a lightsource.
Post by suvakas » Sat Mar 10, 2007 4:15 am
Well..have you tried to render anything else? Does this happen in every scene or only with this one?
Suvakas
gu3st
Post by gu3st » Sat Mar 10, 2007 2:28 pm
I'm going to attempt a simple scene as you said right now, and edit this post with my results.
Edit: it must be something with my scene, becuase I did a simple plane+sphere scene and it's working perfectly. I'll check out my scene and do some bug fixing
Edit2: Figured out that it was the target spot doing the malice.
Thanks guys :)
Dustin
Post by suvakas » Sat Mar 10, 2007 8:29 pm
Great !! :wink:
Suvakas
Post by OnoSendai » Sat Mar 10, 2007 8:42 pm
