[BUG] Object Rotational Motion Blur
- Doug Armand
There seems to be something wrong with object rotational motion blur.
I am trying to render a wind turbine with the props rotating.
The object centre is in the middle of the fan/blades and the rotation is on one axis only. There is no other rotation/location keys. But the renders are turning out a bit wierd as below.
Indigo 2.6.1 x64/Blender 2.49b x64/Blendigo 2.6.1.2/ Win64 x64 and you can download a blender file of this here
http://cid-abf95d459667e8f7.photos.live ... tion.blend
Doug
Doug Armand
Doug Armand
Re: [BUG] Object Rotational Motion Blur
Something weird going on there indeed.
How many animation keyframes are there? You will need at least three per revolution.
- Doug Armand
If by 3 you mean ones for XYZ? then yes Blender has put those in automatically.OnoSendai wrote:Something weird going on there indeed.
For me I've just set 2 X Rotation keyframes. A keyframe on Rotation X of 0 at frame 0 and then another at frame 25 with some random X rotation - random because I'm animating a series of them and I'm just hand randomising the X rotation
I've then set the Rot X curve Interpolation mode to Linear and the Extended mode to extrapolation so they rotate like that forvever
it's probably something stupid that I'm doing but I can't see what - either way it would be nice to find a solution
Doug
Doug Armand
Doug Armand
3, like 3 keys in time as a minimum (3 times xyz). That means that the rotation angle should not be too important, 120°-(rotation for one frame) sounding fine. e: then set the next keyframe by the same amounts.
That said my impression is just that the motion trail is following the Y axis, in Indigo space (the other horizontal axis than x in blender)
The last changes to motion blur was when I added particle instance mb. I think ono is referring to min 3 keys in the exported data, I will check that is the case. However it really does look like x/y have got transposed
Hi Doug,
I think this error occurred because your object has a local rotation and a keyframe rotation on top of that. I'm just trying to figure out the maths now to rotate the keyframes to match the object's local rotation.
- Doug Armand
Not sure what all that means but I am glad your looking into itdougal2 wrote:Hi Doug,
Doug
Doug Armand
Doug Armand
I'm not sure that meant anything at all.... still investigating. The problem goes away if I remove the -90 deg Z rotation
Could it help to treat all rotations as keyframes, multiple or not ? Dunno if that's the case already.
Or check for a "keyframe rotation on top of" when writing meshes down so it comes transformed and ready to endorse the current keyframes ?
Screw the maths, dude
Well, I ended up multiplying each keyframe transformation by the base transformation and it appears to work.
I altered the object to rotate about a non-axis aligned axis (+45 deg around Z) and it rendered OK:
(the text labels indicate the direction the camera is pointing).
I will make a release with this fix soon... after dinner
Please let me know if 2.6.1.3 fixes this issue: http://www.indigorenderer.com/forum/vie ... 42#p102942
- Borgleader
By my understanding of things that would be the appropriate fixdougal2 wrote:Well, I ended up multiplying each keyframe transformation by the base transformation and it appears to work.
(flash video)
- Doug Armand
Excellent work Dougal - that seems to have fixed the problem. BTW your video clip neatly displays the colour problem that Indigo GUI seems to have and that I mentioned as a bug heredougal2 wrote:Please let me know if 2.6.1.3 fixes this issue: http://www.indigorenderer.com/forum/vie ... 42#p102942
http://www.indigorenderer.com/forum/vie ... =5&t=10422
but which some seem to think is by design.
Doug
Doug Armand
Doug Armand
Such a cool picture!
