I know, I just use it to export pigmdougal2 wrote:This is not a Blendigo issue, it is related to the virtual networking present (or not) when running in a virtual machine.
Again, I'll add my personal opinion that running Indigo in a VM is not a good idea.
Blendigo 2.2 Stable
Re: Blendigo 2.2 Stable
Network doesn't work when I export with blendigo linux. It works if I stop rendering and enable network manualy. Is 2.2 still supported?
Can you try to make a distinction between whether this is a Blendigo issue, or an Indigo core issue?Jambert wrote:Network doesn't work when I export with blendigo linux. It works if I stop rendering and enable network manualy. Is 2.2 still supported?
Didn't have any time to test blendigo 2.3 but in 2.2 if you have clayrender enabled and want to render a material preview the clay material is used.
I think it would be better if for material preview purposes the clay tag is automatically turned off and only enabled when exporting the whole scene.
Who wants to do a material preview of the clay material anyway?
Your ad here!
Blendigo issue, autorun breaks network rendering. When I start manualy it works.Can you try to make a distinction between whether this is a Blendigo issue, or an Indigo core issue?
