Blendigo for v1.0.8
Post by BbB » Mon Mar 24, 2008 9:53 am
Thanks Smart. Hope I can find the time to use it soon!
SmartDen
Post by SmartDen » Tue Mar 25, 2008 5:18 am
A little bugfix
Pinko5
Post by Pinko5 » Tue Mar 25, 2008 6:52 am
Tnx Smart !!!
Luca;)
GNUdo
Post by GNUdo » Wed Mar 26, 2008 11:47 pm
Under Materials if I select for Indigo mat. a DIFFUSE type the Transparent button is located in the wrong position, see pic.
Thanks.
Pinko5
Post by Pinko5 » Thu Mar 27, 2008 1:06 am
I have the same problem
Luca. ;)
SmartDen
Post by SmartDen » Thu Mar 27, 2008 2:20 am
Pinko5
Post by Pinko5 » Thu Mar 27, 2008 2:23 am
Tnx ;)
Luca.
GNUdo
Post by GNUdo » Thu Mar 27, 2008 2:26 am
Thank you very much!
Anthor
Post by Anthor » Sat Mar 29, 2008 10:20 am
Thanks SmartDen :)
No solution around duplivert error ? I try instance work with Alt-D but duplivert is ignored.
Thank you
(translate with google :oops: )
Post by StompinTom » Sat Mar 29, 2008 10:33 am
thanks a ton for the exporter!
exporting Groups seems to be broken though....
BLENDIGO v1.0.8
Windows-platform: win32 os.sep: \
indigo path: C:\Documents and Settings\Tomass\My Documents\indigo_v1.0.8\indig
o.exe
Export Still to C:\Documents and Settings\Tomass\My Documents\indigo_v1.0.8\defa
ult.igs
INDIGO EXPORT
Object Plane.004 in layer 6
Object ORTHO_FRONT in layer 5
Object XSECTION2 in layer 5
Object LONGSECTION in layer 5
Object LONGSECTION2 in layer 5
Object schoolEntry in layer 5
Object XSECTION1 in layer 5
Object PERSP_BACK in layer 5
Object PERSP_fromNORTH in layer 5
Object ORTHO_BACK in layer 5
Object backGym in layer 5
Object Camera.003 in layer 5
Object PERSP_fromSOUTH in layer 5
Object admin in layer 6
Object Lamp in layer 6
Processing sun lamp object...
processing Camera...
Film Width 0.035000
FOV: 59.489761
lens-sensor-distance: 0.030625 m
aperture-radius: 0.000696 m
build_lists
Object Plane.004
Type Mesh
Dup 0
Getting Mesh from Object Plane.004
Faces 1
Processing Plane.011 Mesh
material [Material "whiteMatte"] found
Appending material whiteMatte for export
Appending mesh Plane.011 for export
Object ORTHO_FRONT
Type Camera
Dup 0
Object XSECTION2
Type Camera
Dup 0
Object LONGSECTION
Type Camera
Dup 0
Object LONGSECTION2
Type Camera
Dup 0
Object schoolEntry
Type Camera
Dup 0
Object XSECTION1
Type Camera
Dup 0
Object PERSP_BACK
Type Camera
Dup 0
Type Camera
Dup 0
Object ORTHO_BACK
Type Camera
Dup 0
Object backGym
Type Camera
Dup 0
Object Camera.003
Type Camera
Dup 0
Type Camera
Dup 0
Object admin
Type Empty
Dup 1
Object Lamp
Type Lamp
Dup 0
Exporting material [Material "whiteMatte"]
Filename: C:\Documents and Settings\Tom\My Documents\indigo_v1.0.8\default.ig
s
Found 1 Meshes
Exporting Mesh in Scene file
exporting mesh "Plane.011"
exportObjects
exporting object "Plane.004"
Skip "ORTHO_FRONT" (type "Camera")
Skip "XSECTION2" (type "Camera")
Skip "LONGSECTION" (type "Camera")
Skip "LONGSECTION2" (type "Camera")
Skip "schoolEntry" (type "Camera")
Skip "XSECTION1" (type "Camera")
Skip "PERSP_BACK" (type "Camera")
Skip "PERSP_fromNORTH" (type "Camera")
Skip "ORTHO_BACK" (type "Camera")
Skip "backGym" (type "Camera")
Skip "Camera.003" (type "Camera")
Skip "PERSP_fromSOUTH" (type "Camera")
processing GroupObject "admin" (Group "admin")...
exporting object "Cube.009"
File "<string>", line 3016, in buttonEvt
File "<string>", line 2331, in exportStill
File "<string>", line 2309, in export
File "<string>", line 2187, in exportIndigoScene
File "<string>", line 1714, in exportObjects
File "<string>", line 1698, in exportObject
TypeError: argument 1 must be string or read-only character buffer, not None
seems to only happen when im exporting the layer with only Groups on it (Empty objects linked to Groups)
using Indigo 1.0.8 and Blendigo 1.0.8)
delic
Post by delic » Sat Mar 29, 2008 8:05 pm
Nice !
the installer is cool, but, I can only install blendigo for the official blender release, cannot install for other builds, like SSE2 LAA.
This is quite annoying since some exports(the huge ones) only works with these builds that support more than 2gigs of ram.
Should I add env variable paths to get the installer extract for other builds ?
perhaps it doesn't work because I rename usually the blender.exe to fit the build it is ... only the official is called blender.exe on my computer, so I can make Right click,"open with", and choose the build I want open with, 246RC1.exe, 245SSE2.exe, SVN.exe etc ...
pxl666
region overbright?
Post by pxl666 » Sun Mar 30, 2008 11:16 pm
hi
is this an blendigo or indigo issue ?
when i select region render on emitters lit scene - region renders extremely overbright...whats the problem - iam doing something wrong?
cheers
Post by OnoSendai » Sun Mar 30, 2008 11:31 pm
pxl666:
When using region rendering, don't use reinhard tonemapping, use linear or camera tonemapping.
pxl666
Post by pxl666 » Mon Mar 31, 2008 4:22 am
thx ono
5OnIt
Post by 5OnIt » Mon Mar 31, 2008 11:44 am
StompinTom wrote:thanks a ton for the exporter!
Uh!! I thought I was doing something wrong!
Thanks Stompin.
