can't export .obj
5 posts • Page 1 of 1
catsupkid
can't export .obj
Post by catsupkid » Mon Mar 10, 2008 3:55 pm
When I try to export, I get: Python Script Error: Check console.
The console says: AttributeError: Object does not have geometry data.
I am using a topmod object in my scene. I had to import it in .obj format.
I looked at the other post with a similar problem, but that did not help.
If you could help me, that'd be great! :)
Big Fan
Post by Big Fan » Tue Mar 11, 2008 7:03 pm
hmmm as a guess :roll: try saving you blend after import and then re-open
Gog
Post by Gog » Wed Mar 12, 2008 3:18 am
Try making the topmod object local?
catsupkid
Post by catsupkid » Wed Mar 12, 2008 8:08 am
how do I make the object local?
Gog
Post by Gog » Wed Mar 12, 2008 11:08 am
Select the object in object mode, press L then 1
or go to the Object Menu and there is a make local option on the menu.
