Generating/exporting xml files with Blender
6 posts • Page 1 of 1
mcgrathfx
Post by mcgrathfx » Wed Oct 31, 2007 9:49 am
How do I generate/export an .xml scene file from Blender or Blendigo in order to manually edit the scene? I'm using Blender 2.44, Indigo 0.8 stable and Blendigo 0.8t2 beta1d. Michael :D
afecelis
Post by afecelis » Wed Oct 31, 2007 10:37 am
When you press the "export scene" button, an igs file is created. If you leave the "default.igs" buttton selected, the file will be created in your indigo installation with that exact name; if you unselect this option, the file will be created in the same folder as your blender file and will take the same name of your blender scene. You can open this igs file with a text editor and edit it by hand.
Post by Kram1032 » Wed Oct 31, 2007 12:36 pm
why are you using 0.8 stable and not 0.9 stable? (0.9.10)
mcgrathfx
Post by mcgrathfx » Wed Oct 31, 2007 4:12 pm
afecelis: Thanks - I'll give it a try tonight.
Kram1032: Wow! Didn't know 0.9 stable was available yet. I'm pretty new to Indigo and have been so engrossed in learning 0.8! Thanks :D
Post by Kram1032 » Thu Nov 01, 2007 12:01 am
There also is the version 1.0.1 which seems to be pretty stable, too.
The problem is, that you only have a Win32 and a Linux64 bit version....
0.9.10 is available for Win32-64 and Linux32-64 bit :)
mcgrathfx
Post by mcgrathfx » Thu Nov 01, 2007 4:35 am
Thanks for this info - I'll definately be checking out 0.9.10! Michael :D
