error (0.6 release)
13 posts • Page 1 of 1
motorsep
error (0.6 release)
Post by motorsep » Wed Nov 15, 2006 1:31 am
I started rendering of my small scene with alot of polygons (and big .xml file ~ 130Mb). Here is what I got:
What is the deal? (I have P4 1.4GHz 512 Mb RAM)
lego
Post by lego » Wed Nov 15, 2006 2:00 am
I think that the problem is that you have a 90k+ polys object there
try to split it up in smaller objects (this should reduce loading time too)
eman7613
Post by eman7613 » Wed Nov 15, 2006 2:56 am
my expirance is, anything above 84k pollys will crash and die :(
Yes i know, my spelling sucks
atmmatt
Post by atmmatt » Wed Nov 15, 2006 3:45 am
I have an imported stl into blender that ends up being 90 meg, crashes no matter what I do... Only 6 parts but many many many tri's...
"To be, or not to be" That is a question?
motorsep
Post by motorsep » Wed Nov 15, 2006 4:19 am
So what is the way to fix that?
eman7613
Post by eman7613 » Wed Nov 15, 2006 4:36 am
break the object into two. not sure how to do it in blender. IN cinema you select some polygons, click disconnect, go back the original object, and delete the still selected pollys.
motorsep
Post by motorsep » Wed Nov 15, 2006 5:23 am
Doesn't work :/ I have my object splitted on bunch of smaller objects. Sucks.
motorsep
Post by motorsep » Wed Nov 15, 2006 7:06 am
Where is the main guy?! That's not cool :evil:
I was planning on using Indigo for my industrial design projects, but it seems like it's capable of rendering monkeys from Blender only :cry:
Or maybe it because Blender's exporter is crooked :?
Phil
Post by Phil » Wed Nov 15, 2006 8:14 am
Hello,
I am sorry, I is really strange but I do not have such problems. I just made some tests, here are some results:
scene file path: 'glass\glass3.xml'
Using working directory path 'glass'.
created world.
Loading Scene 'glass\glass3.xml'...
Using Reinhard tone mapping with pre_scale=1.000000, post_scale=1.000000, burn=0.800000
Camera: white balance = E, using CIE XYZ chromacity (0.333333, 0.333333)
simple3d mesh vert mem used: 11.250KB (240 verts)
simple3d mesh tri mem used: 1.875KB (80 tris)
Loading tree from disk cache...
-----------TriTree::build()-------------
80 tris.
temp tris mem usage: 2.813KB
intersect_tris mem usage: 3.750KB
calcing root AABB.
max tree depth: 14
total nodes used: 945 (7.383KB)
total leafgeom size: 947 (3.699KB)
finished building tree.
Done.
simple3d mesh vert mem used: 564.656KB (12046 verts)
simple3d mesh tri mem used: 532.594KB (22724 tris)
22724 tris.
temp tris mem usage: 798.891KB
intersect_tris mem usage: 1.040MB
calcing root AABB.
max tree depth: 30
total nodes used: 835891 (6.377MB)
total leafgeom size: 834099 (3.182MB)
Done.
simple3d mesh vert mem used: 7.471MB (163200 verts)
simple3d mesh tri mem used: 7.269MB (317608 tris)
317608 tris.
temp tris mem usage: 10.904MB
intersect_tris mem usage: 14.539MB
calcing root AABB.
max tree depth: 38
total nodes used: 2667201 (20.349MB)
total leafgeom size: 2635452 (10.053MB)
Done.
-----------ObjectTree::build()-------------
5 objects.
calcing root AABB.
AABB: (-300.000000, -300.000000, -300.000000), (300.000000, 300.000000, 421.955383)
max tree depth: 6
reserving N nodes: 5(40B)
total nodes used: 13 (104B)
total leafgeom size: 10 (40B)
Finished initialisation
RendererSettings::getInstance().bidirectional: 1
RendererSettings::getInstance().metropolis: 1
Starting threads... (num threads: 1)
Starting thread...(RNG seed=974232249)
doing initial warmup...
done initial warmup.
Time elapsed: 0s
Done 0.00000 mutations (0.00000 mutations per pixel)
mutations_per_sec: 0.00000 (1.#INF0 micro-secs / mutation)
What is wrong here?
Did I understand something wrong here?
Please tell me!
Should I try with some more triangles?
regards, Phil
motorsep
Post by motorsep » Wed Nov 15, 2006 9:25 am
Do you use Blender and export from it using Indigo exporter?
Phil
Post by Phil » Wed Nov 15, 2006 9:48 am
Yes,
I use blender, and the steps are the following:
Pro/Engineer -> export in obj -> import in Blender
Some transformations in blender and -> export in indigo
Regards, Phil
motorsep
Post by motorsep » Wed Nov 15, 2006 10:58 am
Hmm.. Strange, very strange.. I use Moi3D -> obj -> Blender -> some tune ups -> Indigo. What version of exporter do you use?
Phil
Post by Phil » Wed Nov 15, 2006 11:14 am
I used 0.6 test 6 for the exporter in blender and 0.6 test 6 Indigo.
Regards, Phil
