Light Bulb problem
Light Bulb problem
I am having problems rendering a lamp with a lightbulb. All I am getting is this. This is an aerial view because I was trying to see whether it was illuminating anything inside the lamp. I think it might be something to do with it automatically setting the exposure but I am not sure how to change it manually
- im1174199556.png (18.8 KiB) Viewed 4176 times
Hmmmm now you can't actually see the bulb but what is strange is that you can't see the light emitting fibre mesh either. There is supposed to be orange glass but you cant really see it and I want to know how to make it less transparent but yet again I don't know how.
PS this is from a different angle
- im1174201704.png (82.98 KiB) Viewed 4173 times
- Kosmokrator
Just in case: absorbtion is the contrary of transparency, so the higher the value the more opaque it is. And I second what neepneep says, putting things in vaccum is not a good setup, it's likely the shadow terminators will compute for ever...There is supposed to be orange glass but you cant really see it and I want to know how to make it less transparent but yet again I don't know how
Anthony, can you please give the version of Indigo and exporter you are using, and also do you hand edit xml's or not ? This is important since Indigo has changed these last months and not all exporters support all features.
The Absorbtion I'm talking about is a tag of your glass material in the xml.
I use 0.6 test 6 blender exporter thats all I know with 0.6 test 6
And I don't hand edit stuff cause I don't know how. By the way those other renders weren't the final renders they were screwy cause I didn't render them for long but there is still a problem because I can't see the light emitter through the glass which is weird. I don't really care if I get my lamp finished cause I'm not really working on it now but still something weird is going on
