diffused light - light cone with diffuse filter
Hi
how would you create a light box with a diffused light so it casts only very soft shadows???
I have an issue rebuilding this - to scatter the light ray directions.
claas
claas
Artist : Designer : Educator
of Ferris State University
I see, SSS, I did not think about that. technically you are right.
I made some tests with shooting lights into a light umbrella, wedge gave me the tip, but I had no big success with my results yet.
somehow i needed to crank up the light power significantly!
add cube. scale up. make it a light. done.
the larger the light source, the softer the shadows, the more diffuse the light. all the lightbox is is a very large lightsource (created by putting a flash bulb behind a diffuser so that the diffuser diffuses the light -> bigger lightsource -> softer light).
Also very soft shadows mean the light source is quite wide (like an open, overcast sky). So make the light source bigger (yes a sphere can make sense, depending on the scene). Even if light is scattered at the source, light rays won't come from another point than the source itself (obviously
), so size matters !
