0.7 does not support IOR?
6 posts • Page 1 of 1
mrCarnivore
Post by mrCarnivore » Wed Mar 07, 2007 1:50 am
I downloaded 0.7 test 5 and tried some of the tests that come with it.
However, it seems to not work with any materials that have an IOR, is that a bug or a feature? ;-)
Post by Kram1032 » Wed Mar 07, 2007 2:04 am
Strange.
It's neither, nor: IOR works fine, at least to me...
Do you use the new exporters for 0.7.5?
If not, you should, some of the code completely has changed ;)
Post by fused » Wed Mar 07, 2007 2:16 am
have a look at the manual :)
mrCarnivore
Post by mrCarnivore » Wed Mar 07, 2007 3:26 am
@Kram1032: I used no exporter at all as I used the examples, that come with Indigo itself.
@fused: Was that comment for me? If so, where do yo want me to look exactly? Can you pls be a little bit more specific...
Post by fused » Wed Mar 07, 2007 3:32 am
ok, sry. didnt want to be unpolite.
the indigo manual explains how to use materials/mediums in the right way. it is very helpful.
it is included in the indigo download and can be found in the indigo folder.
Post by Kram1032 » Wed Mar 07, 2007 3:38 am
Yes, that's the problem, I guess...
You use xml-tags from 0.6, but you need those from 0.7...
Especially for transparent stuff, you have to be careful ;)
Transparent mats do need a medium-tag now, where IOR is specified...
In material-tags, you just have to set the type of the mat, the exponent, the name and, if it's transparent, the medium, that should be used!
an example:
<medium>
      <name>Window Glass</name>
      <precedence>10</precedence>
      <basic>
            <ior>1.52</ior>
                  <rgb>
                        <rgb>0.1 0.06 0.08</rgb>
                  </rgb>
      </basic>
</medium>
<material>
      <specular>
            <internal_medium_name>Window Glass</internal_medium_name>
      </specular>
</material>
