This thing is doneski!
There's 10cm, 1m and 10m versions of the scene. Install by unzipping the contents to the indigo program folder. I believe indigo only supports one material scene at a time unlike the old mat editor, but you can run them from anywhere as they use relative paths. Remember to backup ...\Indigo Renderer\data\preview_scenes\mat_db\matpreviewscene_igmesh.igs if you want to keep the current material scene file. That's the only file being overwritten.
All source files are in https://docs.google.com/file/d/0ByfHqmp ... ZSOEU/edit. Uploading that here went on forever. Since blendigo doesn't support tabulated data and exports color as gamma 1, there's some igs fixes included.
Material Preview Scene
- material_preview_10cm.zip
- 10cm scene
- (2.16 MiB) Downloaded 328 times
- material_preview_1m.zip
- 1m scene
- (2.15 MiB) Downloaded 345 times
- material_preview_10m.zip
- 10m scene
- (2.15 MiB) Downloaded 343 times
- PureSpider
Re: Material Preview Scene
Yes that's gorgeous.
I tried IMMEDIATELY to install it, but somehow SkIndigo keeps rendering the elder preview scene..
I am missing something..
It won't work for SkIndigo because SkIndigo uses a preview scene that is installed inside your SketchUp plugins folder. Don't bother trying to install it there because it still won't work. I am guessing the only way for you to use this scene right now is for rendering previews using the Indigo GUI.Pibuz wrote:Yes that's gorgeous.
...OR you could add this wonderful prevew scene in the skindigo preview scene list for a change!
..maybe substituting some less used ones...
I am currently working on preview scene related stuff in SkIndigo...stay tuned. I am not sure if I would add this scene to SkIndigo unless it became the new official scene, I guess we'll see.Pibuz wrote:...OR you could add this wonderful prevew scene in the skindigo preview scene list for a change!![]()
..maybe substituting some less used ones...![]()
