Exit portal tests
Post by OnoSendai » Tue Jun 26, 2007 7:27 am
lwan wrote:Heya,
it's cool to see some Fryrender technology implemented in another rendering engine.
A little credit both for the tech and the tutorial would have been nice though.
Erwan
Yes, well, it's not released yet, but yes, it is a great idea from the Fryrender guys, albeit based on ideas raised as far back as Veach's thesis in '97.
playmesumch00ns
Post by playmesumch00ns » Wed Jun 27, 2007 5:11 am
... and I think it was implemented in finalRender long before fryRender too :)
kadajawi
Post by kadajawi » Wed Jun 27, 2007 11:51 am
Wasn't finalRender a biased renderer? :?
Post by CTZn » Wed Jun 27, 2007 8:36 pm
It is, but maybe the technique is usefull for GI too (using photons); that makes sense.
deltaepsylon
Post by deltaepsylon » Thu Jun 28, 2007 3:50 am
well... the portals should be user defined, cuz for some strange reason someone might not want to use 'em. And it shouldnt be too hard for exporter like blendigo to have exit portal-ization for objects. There could be a list of objects, you select the object and check the little 'exit portal' box. Dunno, just my 2 cents :wink:
Post by Zom-B » Thu Jun 28, 2007 4:49 am
deltaepsylon wrote:well... the portals should be user defined, cuz for some strange reason someone might not want to use 'em. And it shouldnt be too hard for exporter like blendigo to have exit portal-ization for objects. There could be a list of objects, you select the object and check the little 'exit portal' box. Dunno, just my 2 cents :wink:
just make it an new material that can be applied to a mesh, perhaps the easies way for the user, and even to code... +2 cents
Post by CTZn » Thu Jun 28, 2007 5:02 am
Or:
<portal>
    <mesh>
        usual mesh definition
    </mesh>
</portal>
Automatic detection of portals would be very tricky I guess, so yes keep'em user defined !
but you may be right ZmoB, as <mesh> has reference to a material it may be smarter; dunno.
Post by OnoSendai » Thu Jun 28, 2007 5:03 am
exit portals will be defined more or less like a mesh_light, for now
Post by CTZn » Thu Jun 28, 2007 5:06 am
all right.
arneoog
Post by arneoog » Thu Jun 28, 2007 5:31 am
When you use meshlights (I asume that they work for them too)
will Indigo use the meshlight as a light AND an exit portal? :)
Post by OnoSendai » Thu Jun 28, 2007 5:35 am
arneoog wrote:When you use meshlights (I asume that they work for them too)
no.
arneoog
Post by arneoog » Thu Jun 28, 2007 5:43 am
ok Image
