Yes you can get it installed without root, it just looks a little ugly (the process, not the result).
Do you have access to a recent c++ compiler on your Linux machine? (gcc4.x)?
What Distro are you running?
Some help installing Indigo 64 bit Linux
Re: Some help installing Indigo 64 bit Linux
Yes i know, my spelling sucks
I have access to gcc 4.1.2, and it's a 'Red Hat Enterprise Linux Server release 5.3' box.
It would be great if you could help me out, but I'm afraid you'll have to really spell it out for me to get it.
Cheers mate.
Cheers mate.
are you running 64bit or 32bit?
(if you dont know, just copy and paste the output here of "gcc -v")
Here's the output:
Reading specs from /usr/lib/gcc/i386-redhat-linux/3.4.6/specs
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --enable-shared --enable-threads=posix --disable-checking --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-java-awt=gtk --host=i386-redhat-linux
Thread model: posix
gcc version 3.4.6 20060404 (Red Hat 3.4.6-11)Re: Some help installing Indigo 64 bit Linux
well, looks like you are running 32bit - so i cant compile it for you. however you are using redhat which works on rpms. So, you should be able to download an rpm of wxgtk2.8 and install it using
rpm --relocate /path/wyou/wnat/here
however I do not know rpm as well as i phone apt-get, so you may have to look that up yourself.
The other option is for someone with a 32bit installation to compile it for you.
(the dependency list for wxgtk is a nightmare to download yourself by hand, just found that out today.)
