Indigo Phong vs Kerkythea Layered Procedural Fresnel
7 posts • Page 1 of 1
Post by Whaat » Tue May 01, 2007 6:36 am
I was just reading the recently released Kerkythea Material Editor Guide (which patricks has done a great job on BTW). I think giannis and co. have done an amazing job with Kerky but I was surprised how complex it is to create a physically accurate plastic material (no sss). These are the steps as I understand them (see pages 9-13 of the guide) :
- Create a material with two layers
- Layer one is 100% diffuse
- Layer two is 100% specular
- Turn off fresnel attentuation in material panel
- set ior value for both layers (must be the same in both layers)
- Use Procedural fresnel map to control the weights of the layers
- Invert Fresnel ramp low color and high color for diffuse layer
My question is this: Does the Indigo Phong material do all of these steps automatically? In other words, is the Indigo Phong (fresnel scale=1.0) equivalent to the Kerkythea layered procedural fresnel? Or is the Kerkythea material more physically accurate? From what I understand, the two should be the same.
zsouthboy
Post by zsouthboy » Tue May 01, 2007 7:13 am
Phong material is a specular reflector AND a diffuse component. So they're having you set it up correctly.
But, wow, I didn't realize Kerkythea was so hard to set up in that respect.
IDK re: indigo. I'd guess it's physically accurate though.
Why don't you set up a simple cornell box and show us? :)
Post by CTZn » Tue May 01, 2007 8:48 am
That's my opinion also. It appears that Kerkytea is more complex to set up, but also more flexible due to that layer system. But for plastic I'ld stick with Indigo ;)
Post by Whaat » Tue May 01, 2007 8:59 am
CTZn wrote:It appears that Kerkytea is more complex to set up, but also more flexible due to that layer system. But for plastic I'ld stick with Indigo ;)
I agree completely! Kerkythea has a very powerful and versatile system to create materials but I prefer the simplicity of Indigo.
patricks
Post by patricks » Tue May 01, 2007 10:15 am
Hi everybody
if you have read the tutorial until the end you will see that it is not that complicated to setup your materials :wink: You only have to creat once the plastic material and then when ever you need a plastic material , you only have to set the diffuse color or bitmap without any other changes , meaning that in KT we creat materials that will work later with any diffuse bitmap we apply to them without having to go through the whole process again :wink: . At the end it is muche quicker and easy because any person that has created a material can share them with others and they dont have to tweek them again ......
( read from page 10 to 13 again and you will understand :wink: )
Greetings Patrick
Post by Whaat » Tue May 01, 2007 10:35 am
Thanks, patricks. I should have pointed that out in my original post (saving material to be used later). I am sure that material setup in Kerkythea is easy for some :wink: , but I get confused because there are so many options and parameters. How do you know what is the best way to create a material when it seems there are so many choices? For example, what about using a single layer and using diffuse+specular+fresnel attenuation? Is this not physically accurate as well as long as diffuse+specular=1?
Sorry...I guess these questions belong in the Kerky forum...
patricks
Post by patricks » Tue May 01, 2007 10:43 am
Whaat wrote:Thanks, patricks. I should have pointed that out in my original post (saving material to be used later). I am sure that material setup in Kerkythea is easy for some :wink: , but I get confused because there are so many options and parameters. How do you know what is the best way to create a material when it seems there are so many choices? For example, what about using a single layer and using diffuse+specular+fresnel attenuation? Is this not physically accurate as well as long as diffuse+specular=1?
the answer to your question is "NO" it would not be accurate and i explain it in the Manual why it is not accurate (page 8 to 12 ) .
A lot of people dont want to creat there materials , that's why you can download the basic plastic material vol2 for example ( and others too ) and you only have to select one of them and add a bitmap or give it a diffuse color ( maybe bump map ) and that's it , no other changes have to be don and you get your accurate plastic material or any other you have selected from the liabrery ( i think it is quite easy .... i dont know any more easy way .....)
Greetings Patrick
