Exponent map doesn't seem to work as I expect.
A B and C just wors as spectral exponent, multiplier and adder, or?
C makes brighter
B makes wider
A makes extremely much wider
For a good use, this is reqired, I guess, as there only are 256 greyscaled steps... You have to define, how they are used. If you don't do this, it will be very hard, to use a map correctly, sometimes... I guess, at least...
(I finally understood A B and C,
Maybe you could use greyscaled .exr ? For more accuracy....
(If that works....)
C makes brighter
B makes wider
(If that works....)
