SSS Lampshade Tests
Post by Kram1032 » Mon Apr 02, 2007 10:13 pm
5000 k for daylight?
Normally, the sky colour is taken for this...
Although the sun has a very weak-yellowish white, things at daylight look more blueish - the sun lit sky colours them, so that you should use 7500K
(D75)
...or?
Post by OnoSendai » Mon Apr 02, 2007 10:15 pm
I think D65 is the standard for outdoors, skylit stuff
Post by Kram1032 » Mon Apr 02, 2007 10:18 pm
aha...
But not 5000K
hmmm: 6500K - Television, sRGB color space
7500K - ___ (colour next to it looks more like sky, to me...)
http://en.wikipedia.org/wiki/White_point
Marcofly
Post by Marcofly » Mon Apr 02, 2007 10:38 pm
interesting test!
don´t understand a couple of things.. maybe somebody could help me..
-what is MNCR?
-which kind of emitter are you using for this test?
thanks!!
Marcofly
Cire
Post by Cire » Tue Apr 03, 2007 11:13 am
MNCR: Maximum Number of Consecutive Rejections
As for what it means, someone else will have to explain that. I do know that lower values increase render speed, while higher values increase render accuracy.
Marcofly
Post by Marcofly » Wed Apr 04, 2007 12:18 am
Thanks Cire, it was a stupid question :oops:
Bye!!
Phoenix
Post by Phoenix » Wed Apr 04, 2007 5:35 am
Kram1032 wrote:aha...
But not 5000K
Here are also good sources to answer these questions:
http://www.cambridgeincolour.com/tutori ... alance.htm
and http://www.nikondigital.org/articles/white_balance.htm
And the examples for different Lightsources from the second link (there is also a similar list on the first one):
1000k -- Candles, some flashlights
2000k -- Pre-sunrise
2500k -- Household bulb, used
3000k -- Household bulb, new / some studio lights
3000-4000k -- Sunrise / sunset (without the influence of heavy smog/smoke)
4000-5000k -- Fluorescent bulbs, cool white - "daylight" balances
5000-5500k -- Electronic Flash, portable (new bulb)
5500-6000k -- Studio Electronic Flash (new bulb)
6000-7000k -- Sunlight, bright day
7000-8000k -- "slight" overcast skies at lower elevations
8000-9000k -- Heavy overcast / slight shade
9000-11000k -- Rain at lower elevations / clear day at higher elevations (above 8000 feet)
11000-18000k -- Overcast to snowy days at higher elevations (above 8000 feet)
mrCarnivore
Post by mrCarnivore » Wed Apr 04, 2007 6:33 pm
Does that support my statement, that daylight films are set to 5000K? :D
Post by StompinTom » Wed Apr 04, 2007 8:42 pm
daylight film is balanced to 6500K as far as i know. tungsten film (indoor film) is somewhere around 3000K or so.
Post by Kram1032 » Wed Apr 04, 2007 9:36 pm
between 3000 and 5000, as it looks like ;)
stay at "A" and 5000 ;)
SmartDen
Post by SmartDen » Fri Apr 06, 2007 2:43 am
Here is my lampshade test
Meshlight behind SSS Lampshade and HDRI outdoor lighting
Post by Kram1032 » Fri Apr 06, 2007 2:58 am
looks GREAT!
I like the window! Looks soooo great!
crc
Post by crc » Wed Apr 11, 2007 6:15 am
Hey Whaat-
those look really great!!!
about what opacity did you set those at, I know that you changed it for each shade, but maybe as a starting point to help some of us noobs.
thanks!!
Post by Whaat » Wed Apr 11, 2007 6:46 am
If I remember correctly, I had the Sketchup opacity slider set at 75 for all of the shades. Only the RGB values were different for each one. The thickness of the shades is very important. I used 1/16".
