Setting Max Num Consec Reject To 0
6 posts • Page 1 of 1
nakile
Post by nakile » Mon Mar 26, 2007 8:55 am
I decided to run a few test scenes to see what would happen if I did this.
The following were both done in about two hours on a Pentium 4 running at 2.4 Ghz with Max Num Consec Reject at 0.
From what I understand, this is about as bias as Indigo can get, correct? Even so, those images look good for running a few hours, I think.
I guess I'll have to run those scenes again for the same amount of time, but at 1000.
Post by Kram1032 » Mon Mar 26, 2007 9:00 am
yes, you're right and yes, you should :D
Post by CTZn » Mon Mar 26, 2007 9:16 am
I hope the <halt_samples> tag will be available soon :D
It's much more relevant than a <halt_time> for such tests !
nakile
Post by nakile » Mon Mar 26, 2007 1:10 pm
Strange... I ran the first scene for only an hour with it set on 1000 and came up with this:
Deus
Post by Deus » Mon Mar 26, 2007 6:13 pm
Yeah. Really strange. The real question is where did that monkey head that was in the first image go? The real mystery is begining to be uncovered.
Post by Kram1032 » Tue Mar 27, 2007 1:01 am
that really shows the effect of max_num_consec in an impressive way :D
Quality gets much better, but noise disappears slower.
Therefore, shadowed regions stay extremely noisy.
-> Indirectly lit scenes and scenes with caustics : high max_num_consec
