Deus
by Deus » Sat May 05, 2007 11:06 am
08_1 release
I have a material that is a blend between null and textures (LEAFS)
<material>
<name>leaf1noalpha</name>
<diffuse>
<colour>0.400 0.400 0.400</colour>
<albedo_texture>
<uv_set>uv</uv_set>
<path>textures/Leaf4.jpg</path>
<exponent>2.300000</exponent>
</albedo_texture>
</diffuse>
</material>
<material>
<name>leaf1</name>
<blend>
<a_name>null</a_name>
<b_name>leaf1noalpha</b_name>
<blend_factor>uv</blend_factor>
<blend_map>
<uv_set>uv</uv_set>
<path>textures/Leaf4alpha.jpg</path>
<exponent>1.000000</exponent>
</blend_map>
</blend>
</material>
Exactly same scene 07 and 08
works perfectly in 07
Looks like this in 08 (look at the leafs)
whats up?
- im1178317174.png (478.13 KiB) Viewed 2416 times
by Kram1032 » Sun May 06, 2007 12:04 am
dunno, how to fix it, but:
t1?
t2 already is out
by CTZn » Sun May 06, 2007 12:10 am
maybe in the future it would be better to post a detail from the image rather than scaling it down... the issue is not really obvious.
I think there was a similar problem with early 0.7 wich has been adressed later, should be easy to fix (again).
by Kram1032 » Sun May 06, 2007 12:21 am
Oh yes, it is:
Look at the leaves, that are closer to the camera and lit better.
There in the foreground.
You definately can see, that it's just the colour - texture with that white frame, where it should be cut out with the alpha map
by BbB » Sun May 06, 2007 6:17 pm
Yes. Got the same problem. You can't do ivy with Indigo8. Null material appears as diffuse when blended...
by OnoSendai » Sun May 06, 2007 7:05 pm
Ok, I think I found the problem, fixed now.
by Kram1032 » Sun May 06, 2007 8:07 pm
you mean for 0.8t3, right?
by OnoSendai » Sun May 06, 2007 8:29 pm
Yes, will be fixed for test 3
