I think there is an opportunity here to think about MDL.
"Okay" this is Nvidia and originaly based for iRay, a kind of no-spectral renderers. But this Material Definition Language could be very interesting to prove that a spectral renderer don't give the same image than a pure faky RGB renderer actually do.
http://developer.download.nvidia.com/de ... 512.A4.pdf
http://www.mdlhandbook.com/mdl_handbook/index.html
[REQ] MDL compatibility
errare humanum est
Re: [REQ] MDL compatibility
Mdl is spectral since last year and more and more programs use it.
So is it still not in the schedule?
errare humanum est
What would the direct advantages be for normal users?
Sounds good. Is MDL big enough to consider an industry standard? Are people actually able to transfer materials between the biggest render engines currently using MDL?
The Substance Painter stuff could be a big plus for sure.
Support for Substance Designer should really be considered, even if it comes by the means of a material converter.
Actually, I use Substance for the trivial materials and if you can save my time in my workflow, it would be fantastic.
However, if we compare the chalenger "MaterialX" seems to be less appreciated by 3D industries, and the Nvidia compressor roller has already taken place in quite a few softs.
You have quoted Substance, but Vray, Guerilla renderer are also in the happy fews for the same reasons.
Regarding AfX, It appear that Xrite doesn't really comunicate on his TAC7 scanner so it could be difficult to do a trustable comparison. In the same time I heard that Optis are hable to handle MDL so... that sound good isn't it?
errare humanum est
Lol, if you use Indigo, you are definitely not normal in the "normal" CGI world hahahaOscar J wrote:What would the direct advantages be for normal users?
errare humanum est
For now, yes. Obviously the goal is always to make Indigo more popular.Jay-ko wrote:Lol, if you use Indigo, you are definitely not normal in the "normal" CGI world hahahaOscar J wrote:What would the direct advantages be for normal users?
