Help, I waited 10 hours to get a terrible result
Come here for help & support.
7 posts • Page 1 of 1
riaheckler
Post by riaheckler » Fri Jul 23, 2010 6:06 am
Hello everyone, I'm newbie here.
I have tried Indigo for 2 days, I made a scene in Blender and got the rendered image after 26 seconds using Blender Internal (second attached image), then I tried to render it in Indigo, hoped to see how realistic it could be, I left the default settings in Blendigo, and after 10 hours and a half, Indigo gave me what you see in the first image :shock: it didn't even finish my scene, let alone the realism.
There must be something wrong here, that result didn't worth 10 hours, can anyone help ?
>10 hours in Indigo
26 sec in Blender Internal
Godzilla
Re: Help, I waited 10 hours to get a terrible result
Post by Godzilla » Fri Jul 23, 2010 6:54 am
The textures from your scene weren't set up correctly in the Blendigo exporter, it seems. You need to enter a UV name in blender and in the exporter tab, as well as specify a path to the texture.
http://www.indigorenderer.com/documenta ... go|outline
PS. Why did you let it render for 10 hours? you would have been able to see within a few minutes at the most that it wasn't rendering correctly?
Soup
Post by Soup » Fri Jul 23, 2010 1:00 pm
Indigo renders never 'finish'. Just stop it when you are happy with the result
(Faq link: http://www.indigorenderer.com/faq#12n970)
Post by StompinTom » Fri Jul 23, 2010 4:16 pm
Blame the tools, not the artist!
riaheckler
Post by riaheckler » Sat Jul 24, 2010 4:21 am
It looks like Indigo doesn't support normal map and procedural texture
Post by Zom-B » Sat Jul 24, 2010 5:04 am
he he, no Indigo doesn't!
convert your normal maps into bump (displacement would be better, but it is quite broken atm)
bake your procedural to a texture, and use it as a map...
check out the latest blendigo Manual for a smoother start into Indigo ;-)
http://www.indigorenderer.com/sites/def ... manual.pdf
FiveAG
Post by FiveAG » Tue Jul 27, 2010 10:34 pm
he,he, an outsider!!
