CoolColJ's test pics thread
here is Ian's solution with Radium recently after I brought this up - hope Ono can take something from this
Right, I think I'm onto something now. A few extra lines of code and winching the MCR (MNCR) up to 50,000 has resulted in this after only 30 mins:
http://www.trackvids.co.uk/radium/galle ... water3.jpg
It's still a bit patchy but I think I can refine it even further.
The way it works is fairly simple... if the path generator detects a sun caustic (direct or indirect) it instructs the next mutation to set MLT_MAX_CHANGE to zero for mutations at diffuse surfaces. This exploits the fact that the sun is omnidirectional and almost guarantees that many of the subsequent mutations find the sun again. It's unbiased too
Ian.
Unfortunately the above render died overnight (the laptop hibernated and killed all the running processes... oops)
But... I resurrected the original pool scene (provided months ago by clipi based on an Evermotion scene). I had to import into Blender from .3DS, copy and paste Colin's water into it and re-export as .OBJ.
Seems this optimisation works extremely well for the underwater caustics... they were nearly perfect after 30 mins rendering across 12 cores but I left it for a total of around 2 hours just to see if the directly-viewed caustics on the walls would resolve a little better (they didn't but I've not implemented the full optimisation for these yet):
http://www.trackvids.co.uk/radium/gallery/pool2.png
The MCNR was set to 500,000, max_change (default) at 0.003 with diffuse bounce max_change dynamically changed to 0.0 for certain paths (as described earlier).
Just a sidenote ... no-one should ever be afraid to set MCNR way high... it only affects the complex paths and won't introduce any fireflies on well-lit diffuse surfaces. I've previously rendered a diffuse Cornell Box scene with MCNR set to 2,000,000 and it's indistinguishable from a 100 MCNR render after the same amount of time
is someone playing Jedi mindtricks on me?! I do believe I see some underwater caustics
all default settings too....
new version of Cindigo scales ray_origin_nudge_distance with the global scale multiplier of 0.01 to this <ray_origin_nudge_distance>0.0000010000</ray_origin_nudge_distance>
default is 0.0001
hmmmm
pic to come..
default is 0.0001
hmmmm
pic to come..
progress so far at 800 samples, default settings but with MNCR jacked up to 50,000. Those Water surface highlights show up really quickly with MNCR this high. I have another render going with the default MNCR of 1000 and I don't see any surface specular highlights yet, but there looks to be some dots so they may show much later
Still, they are building up dot by dot... slow... but they appear to be in a wave type shape this time.
I removed the smoothing off the water, which got rid of a few shading/smoothing errors and the ripples in the water surface show up better. Water has 66,000 polys so probably doesn't need smoothing anyway, at least from above. Underwater is a different story
This is gonna look real nice with bloom and glare once it's all finished up and clean. Just hope those caustics show up, however slim a chance that may be....
water really needs specular highlights and caustics to look sunny. I have the sun almost directly above, ie Noon
- CCJ_Water_inProgress.JPG (90.04 KiB) Viewed 3619 times
well I didn't use Blender for this scene though
But that would definitely help, water is pretty tricky smoothing wise
A long render time even with lower MNCR. Most of the renders I have done with any amount of reflective surfaces and caustics needed to be rendered into the 7000-8000 samples range to be even considered near finished
I resumed the render with MNCR cranked up to 500,000 and this is what it looks like at just under 3000 samples. I think it's about 40% near finished.
I'm confident those white things are caustics to be
Once they smooth out and blend in a bit more. I just wished they would show up quicker like when the camera is underwater!
For one you only see them in the non shaded areas of the water and only in places where you can see the refracted floor. There is none of the right hand side where you can't see the floor due to the reflections.
Keeping my finsgers crossed
I also did a render with stock settings of MNCR of 1000, Max change 0.01, Large Mutation probability of 0.4. That is what it looks like at 2500 samples and it hasn't changed much in the last 1500 samples
I think MNCR of 1000 is definitely insufficient for complex light paths...
Definitely not unbiased. I'm going to set my general default MNCR to 1 million and leave it at that
This pretty much proves that fireflies with MNCR 1000 is just incompletely rendered caustics/reflections in the MLT pathways. Low MNCR renders don't get this because the paths are cut short!
- Default MNCR 1000 version
- CCJ_WaterTest_MNCR1000_2500samples.JPG (76.68 KiB) Viewed 3497 times
- MNCR 500,000 version
- CCJ_WaterTest_MNCR500000_2950samples.JPG (89.75 KiB) Viewed 3497 times
MNCR 500,000 is too high, but 50,000 works well
It puts more emphasis on the important light paths in your scene without neglecting the rest. 25,000 to 50,000 is what I like so far after more tetsing
I'm up to 6500 samples and still no end in sight!
this one is gonna take till 20000+ samples to finish! Me thinks Ono needs to do some paths tweaking ala Ian with Radium
