my new project the trumpet
Hi everybody, this is my first image with Indigo, 3DSMax2008 modelling and
10 rendering hour, but is still noisy.
I don't know if it simply question of time and to wait or if I made same mistake during the material setup or lighting (direct light+skylight)
C&C are welcome
Sax
C&C are welcome
Sax
- trumpet.jpg (166.95 KiB) Viewed 9549 times
Got some nasty firefiles there.
Can you send me the .igs scene file?
nickamy@paradise.net.nz
thanks.
thanks.
Hey Ono,
I tested Indigo on my two last commercial projects (just to see what the result is). And I always had fireflies. A bit less with MLT, but with PT the fireflies didn't go away even at 12k samples per pixel. Also when using dispersion the result was unpredictable. With dispersion + PT I sometimes got random colored fireflies and with MLT I got multy-colored areas. Whenever there are caustics in the scene the result seems to be unprredictable here. Also those fireflies start glowing when there is aper.diffraction turned on (more with filter and less without it). (I've been too busy to make a bug report.. and i'm also not very sure if it's a bug or should i render my scenes longer, but I think 12k samples should be enough.) I won't post any images, cause this is saxo's thread and i don't want to ruin it with my garbage.
