ferns
fenerolina
ferns
Post by fenerolina » Mon Feb 08, 2010 9:04 am
Hi everyone!
I've just uploaded a fern leaf material. So now you can make, with a bit of organisation, beautifull green pictures like these:
Hope you like..
galinette
Re: ferns
Post by galinette » Mon Feb 08, 2010 9:40 am
These are renders???
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
fenerolina
Re: ferns
Post by fenerolina » Mon Feb 08, 2010 9:53 am
Yes they are! I knew you'd like it.
Notice the second one is a bit noisy and has some fireflys. Sorry for the noob question but how can I upload a bigger image for you to click on it and watch it full size.
Re: ferns
Post by zeitmeister » Tue Feb 09, 2010 6:58 am
This is stunning, fenerolina!
Polinalkrimizei
Re: ferns
Post by Polinalkrimizei » Tue Feb 09, 2010 8:43 am
Yes it is, thanks for sharing!
Your preview-pictures look photo-real, I wish I could see those in the matDb. Benn?
Re: ferns
Post by OnoSendai » Tue Feb 09, 2010 10:19 am
Very nice material.
My only suggestion would be to add <step_blend>true</step_blend> to your blend materials. This will get rid of the fireflies.
Re: ferns
Post by zeitmeister » Tue Feb 09, 2010 11:05 pm
... but "step blend" kills gradients in blend maps, doesn't it?
Well, if provided.
Soup
Re: ferns
Post by Soup » Wed Feb 10, 2010 10:13 am
It will kill gradients, but that shouldn't matter on a material like this - so long as the blend map is high enough res
Re: ferns
Post by OnoSendai » Wed Feb 10, 2010 10:19 am
zeitmeister wrote:... but "step blend" kills gradients in blend maps, doesn't it?
Well, if provided.
Correct, it makes the material either completely transparent or completely opaque, depending on the value of the blend map. Which can be good, because it gets rid of fireflies due to partial transparency :)
Re: ferns
Post by CTZn » Thu Feb 11, 2010 6:29 am
Also step_blend has the advantage to borrow (filter) pixels at the B/W interface, wich is a nice and sometimes usefull (ie: fonts) effect.
Bravo fenerolina !
Re: ferns
Post by zeitmeister » Fri Feb 12, 2010 12:55 am
Thanks for the info!
fenerolina
Re: ferns
Post by fenerolina » Sat Feb 13, 2010 12:00 am
I'm very glad you like it! :D
I'm afraid I don't understand when Ono says "add <step_blend>true</step_blend> to your blend materials" I know I have a lot of lacks in texturing, but could somebody explain it for me in more details?
Thank you.
Re: ferns
Post by PureSpider » Sat Feb 13, 2010 12:27 am
Step blend is: "Everything below 50% white in the texture becomes 0% white (black) while everything above 50% white becomes 100% white"
That way gradients are killed but the rendering is more "efficent".
fenerolina
Re: ferns
Post by fenerolina » Sat Feb 13, 2010 12:40 am
Thank you Purespider!
:oops: but my noobish question is where do I have to input this value in the texture?
galinette
Re: ferns
Post by galinette » Sat Feb 13, 2010 12:37 pm
In that case, I think fenerolina wanted to achieve a semi-transluescent material, by blending a diffuser and a diffuse transmitter. I do not think you can do the same with step blend
Etienne
