Milk (regular) optimized
Meelis
Re: Milk (regular) optimized
Post by Meelis » Wed Dec 22, 2010 7:31 pm
Thanks i try it out
Now i lowered sss uniform value to 200 from 500 and did some fast hdr tests.
The noise is much more even and not like fireflies
160k s/sec vs 19k before
I gonna restart render with lycium recommended settings
Meelis
Post by Meelis » Thu Dec 23, 2010 12:41 am
:D :D :D Yes bidir of with MLT path tracing and the noise will go away very fast, i can even use higher SSS uniform value.
Here is fast preview with HDR lighting.
Also female figures 30cm tall (1st was 20cm). And gemstones are way to big (1cm grid) :)
And milk material scattering is 2,5x more isotropic.
http://static3.nagi.ee/i/p/692/54/17313693dcc60f_o.jpg
dag
Post by dag » Fri Dec 24, 2010 6:24 pm
PT only at 3k spp.
Looks like 500 sss is too much.
How do you get the liquid to "fill" the glass on the sides, like in real lifes?
Used about 0,3mm space between glass and milk.
Silmä
Post by Silmä » Fri Dec 24, 2010 6:54 pm
There should be no gap (the meshes should intersect), but difference in materials precedence value. The precedence tells indigo how to clip intersecting mediums (eg. glass and milk).
Higher precedence wins and lower gets clipped.
Meelis
Post by Meelis » Fri Dec 24, 2010 8:25 pm
I guess value 200 is better than 500, in case the milk doesn't get too transparent :roll:
dag
Post by dag » Mon Dec 27, 2010 5:54 pm
In the process of finding out I was dead wrong I made this, which to my surprisement doesn't render correctly in intercrap explorer.
http://www.home.no/faenskap/3d/scatteri ... media.html
Just doing a quick testrender now to check the mat (at 4k s/s) . Woohooo!
Meelis
Post by Meelis » Mon Dec 27, 2010 6:56 pm
RGB scattering coefficient spectrum was very very slow, atleast in bidir mode.
Maybe i should test it in path tracing mode :roll:
And the default Henyey-Greenstein G Spectrum looked very transparent with that low (fast) Scattering Coefficient.
Post by CTZn » Tue Dec 28, 2010 12:47 am
Meelis wrote:RGB scattering coefficient spectrum (...) Henyey-Greenstein G Spectrum
>> MLT all the way :)
Meelis
Post by Meelis » Tue Dec 28, 2010 1:26 am
>> MLT all the way :)
So with that material MLT use is enforced automatically?
Anyway path tracing with G Spectrum RGB ~ 2000 values was slow.
Uniform value 2k-3k and less isotropic scattering looks much more reall but still way too slow
compared uniform 500 and more isotropic scattering.
Post by suvakas » Tue Dec 28, 2010 2:52 am
I re-rendered my old milk test.
It's a low-fat milk :)
Ps. Rendering speed seems quite acceptable. (MLT, bidir off)
Doug Armand
Post by Doug Armand » Tue Dec 28, 2010 3:09 am
Nice one Suvakas!
Doug
Doug Armand
Meelis
Post by Meelis » Tue Dec 28, 2010 3:29 am
suvakas wrote:I re-rendered my old milk test.
Looks very good and fast same time.
What's the material?
yes low-fat indeed :)
Why high absorbing material (~ 600 /1m) with non isotropic (measured) scattering (0.98) looks transparent
Here is same material with isotropic scattering (too wax like)
Post by CTZn » Tue Dec 28, 2010 5:22 am
Meelis wrote:
>> MLT all the way :)
No, that's not what I meant Meelis, and I for one wouldn't like the idea of enforcing modes. But, in terms of performances with the aforementionned parameters, MLT will (almost ?) always give the best results.
As a conclusion, saying that MLT is always slower is not true (you didn't say this neither, this was a general remark).
However it is interesting to stress the other modes with such a material like you do, optimisation wise !
Nice one suv, that's pretty fast indeed.
Godzilla
Post by Godzilla » Tue Dec 28, 2010 2:12 pm
Finally got around to rendering that scene. I wasn't able to get rid of all the noise, I think upping the supersample level would have helped a bit more (Set at 4 here). I removed the jewels - hope you don't mind.
Small version with noise reduction in PS
Full size
http://farm6.static.flickr.com/5008/529 ... ce93_o.jpg
Meelis
Post by Meelis » Tue Dec 28, 2010 6:54 pm
Godzilla wrote:Finally got around to rendering that scene. I wasn't able to get rid of all the noise, I think upping the supersample level would have helped a bit more (Set at 4 here). I removed the jewels - hope you don't mind.
Full size
:D Thank you
