what is this error??? help plz
5 posts • Page 1 of 1
cyber_b_u_g
Post by cyber_b_u_g » Wed Jul 07, 2010 9:20 pm
hey guys!
i created a model in sketch up and i have done everything from softening the edges to putting matherials all over the model,there is no problem untill i click on render button for indigo and most of the time this error keeps popin out and stops the rendering prosess.....( i have used displacement map on some of the matherials and bump on the others ) please if anybody knows what is it and is aware of the solution do no hesitate to help...
wojtek-w
Re: what is this error??? help plz
Post by wojtek-w » Fri Jul 09, 2010 4:43 am
hi,
there is an issue with displacement in sketchup (or rather skindigo). try to lower subdivision level or use bump instead.
FiveAG
Post by FiveAG » Fri Jul 09, 2010 12:31 pm
I encountered the same problem too.
That means too many digital amount.
If you get a computer system having large mathematical ability.It maybe not appear.
Post by CTZn » Fri Jul 09, 2010 2:11 pm
The error can happen in two cases:
- you wanted to displace a plane and you ticked the option to smooth the subdivided shape: the plane can collapse into a very small and heavy geometry.
:arrow: disable the shape smoothing
- you wanted to displace an object whose faces weren't merged, leading to multiple collapsed faces, as above.
:arrow: set all faces smooth to allow them to be sewed.
Unfortunately this answer is more a generic Indigo answer than SkIndigo specific, it will require some interpretation from you, or some more help from SkIndigo users :)
Post by fused » Fri Jul 09, 2010 2:14 pm
Try using the latest indigo version. 2.4.4 or newer.
