Hi the guys ...i have a question ....
What is the procedure in Skindigo to achieve that light effect on tree leaves?.That effect where some parts of a surface seems to absorb the light (Like in the image attached...Well first off...is that possible to achieve with Indigo?
Regards
Tree leaves
- zeitmeister
Re: Tree leaves
Of course! You need the double-sided thin material and a greyscale texture-map for the translucency.
You checked out Ono's leaf material in the MatDB?
Cheers, zeiti
Cheers, zeiti
Re: Tree leaves
Hi !zeitmeister wrote:Of course! You need the double-sided thin material and a greyscale texture-map for the translucency.
Cheers, zeiti
No, i haven't. I will take a look at the material right now ! ( I guide would be really helpfull ..i am totally lost with the indigo's material creation )
I think that effect increase a lot the realism in the renderings , so i really want to learn how to make it
Re: Tree leaves
In Skindigo, you will want to use the 'simple thin' material.
It converts to a double-sided thin material in Indigo.
Re: Tree leaves
Hey Thx ! I never thought it was that simple (unless i'am doing someting wrong ) . I only changed the "pong / specular" for "Simple Thin "..... Was that what you meant that i do Ono ?OnoSendai wrote:In Skindigo, you will want to use the 'simple thin' material.
I attach some samples:
01 Only Pong /diffuse and a map applied.
02 Only Simple thin and a map applied.
Re: Tree leaves
yes, that sounds right.Lal-O wrote:Hey Thx ! I never thought it was that simple (unless i'am doing someting wrong ) . I only changed the "pong / specular" for "Simple Thin "..... Was that what you meant that i do Ono ?
Re: Tree leaves
Yeah! Thank you so much OnoSendai!OnoSendai wrote:yes, that sounds right.Lal-O wrote:Hey Thx ! I never thought it was that simple (unless i'am doing someting wrong ) . I only changed the "pong / specular" for "Simple Thin "..... Was that what you meant that i do Ono ?
My best regards.
Re: Tree leaves
Yes, a guide about making complex materials using the different plugins would be wonderful!
+1 Lal-o
+1 Lal-o
