GLass Properties
7 posts • Page 1 of 1
scarto
GLass Properties
Post by scarto » Wed Sep 05, 2012 11:11 pm
Hi. i'm trying do render with indigo, but i have a problema. I do not know what to do to get the glass without those defects. this is the example. please help me. Does anyone have a clue?
galinette
Re: GLass Properties
Post by galinette » Thu Sep 06, 2012 9:40 am
Yes, do not use PT (disable GPU acceleration, and use MLT or Bidir MLT)
Eclat-Digital Research
http://www.eclat-digital.com
Post by CTZn » Thu Sep 06, 2012 10:09 am
And check Glass Acceleration on, it should be a good helper here.
GLass Properties
Post by Headroom » Thu Sep 06, 2012 1:35 pm
I think we should make GPU support illegal :-))
ATI Radeon HD 5750M 1024 MB
OS X 10.10.3 Yosemite
scarto
Post by scarto » Fri Sep 07, 2012 12:10 am
i do everthing, but the glass continue the same. In material type what i chose??
Post by Pibuz » Mon Sep 10, 2012 7:33 pm
If you want to get rid of all problems, you should choose the Thin Glass shader, ALTHOUGH IT IS NOT A REAL PHYSICS-BASED MATERIAL and it could lead to different kind of issues. BTW, just try it: it can work with flat surfaces. If the fireflies still apppear, it means that what causes you problems here is something else. Also lower the whites to 210 210 210.
galinette
Post by galinette » Mon Sep 10, 2012 8:35 pm
scarto wrote:i do everthing, but the glass continue the same. In material type what i chose??
Can you show us pictures? Because with MLT, the problem should at least look different, it cannot look the same
Etienne
