It looks the surface is subdivided into triangles, and two of them are almost singular (ie they have a nearly zero height). Then calculation of the normal is then likely messed up (computing the normal of a nearly singular triangle is very prone to precision issues)
Subdividing will maybe solve the problem, but Indigo will not subdivide unless there is displacement mapping.
I would try doing some manual subdivisions in sketchup : for instance, create a rectangle surrounding the hole on the face.
Wireframe Lines Coming Through
Re: Wireframe Lines Coming Through
Eclat-Digital Research
http://www.eclat-digital.com
Sorry for replying so late...I must have missed your post on page 2. Adding a rectangle around the problem areas (curves) only intensifies the problem. This should be reproducible by anyone.galinette wrote:It looks the surface is subdivided into triangles, and two of them are almost singular (ie they have a nearly zero height). Then calculation of the normal is then likely messed up (computing the normal of a nearly singular triangle is very prone to precision issues)
Make a surface and put a circle in it. Then apply the brushed aluminum material.
Intel Core-i7 @ 4.0 GHz | GTX 580 | 12 GB RAM
