Still, I also find that we will need a better method to guess the obj materials than trial and error. So I hope this is a basis on which a more sophisticated procedure will be built on. Go Dale!
can you add a script to connect a found orphan material to an igm file by inputbox before it export to indigo???Whaat wrote:...
6) Try rendering with Indigo. You will get error messages because Indigo cannot find the proper materials for the external file. Take note of the name of the material in the error message.
problem solved!Pibuz wrote:Hi Max! I understand the first error (I don't know why I didn't include the extension....I usually do)
But I don't manually WRITE the obj, that is just as exported from TreeD!
How can I fix that?
EDIT: fixing the path doesn't solve the problem, same exact issue
Pibuz wrote:BTW, MeshLab "fixed" the geometry problem indeed..
Now...is it possible to rotate the axis of the mesh?
