Hi:
I am new and I have in my computer Vray for sketchup and when I install SketchUp Exporter and ask me to locate the Indigo.exe they crash my install of Vray, anybody have the same problem?
Thanks.
Indigo crash Vray render in Sketchup....
Re: Indigo crash Vray render in Sketchup....
anyone can reply about this issue form the forum, any moderator?..
thanks.
thanks.
I actually confirm some kind of conflict between Vray4SketchUp and SkIndigo, but I used to work with both apps installed a few time ago. Now I exclusively use Indigo, so I don't have this problem any more. Sorry I cannot help you a lot..
As I don't have VRay, I am unable to test. If any SkIndigo users have VRay, can you confirm if there is a problem? Thanks!
I have Vray. No problems here.
hi
I have Vray too and no problem to report.
If could post your versions of SkIndigo, Vray, SketchUp, that may help too.Gonzalo66 wrote:Hi:
Thanks.
Hi
Last time, i tryed to use a sketchup model in which i had already made all my indigo settings and tryed to use it in Artlantis, and it did not work, but if you type the SkIndigo.purge_model and Skindigo.purge_mats commands in the ruby console, it worked again
maybe, if you create a backup of your skp file and type these it will work.
hope it helps you
hope it helps you
