How can I simulate realistic fog?
crojack
Post by crojack » Tue Jan 15, 2008 5:03 am
pxl666 wrote:but is this a scene put into a "box of fog" or is it a scene rendered with fog switch ON? im a blendigo user and i didnt find any fog switch - is there any way to turn it ON in blendigo?
Sketchup has a fog setting that renders it inside the model, that is what he used above I believe. It doesn't have very much control on where it is though, just foreground and background.
Whaat,
what is the difference between Specular and Glossy Transparent?
Like, when to use which one?
Thanks
Post by Whaat » Tue Jan 15, 2008 5:10 am
crojack wrote: Whaat,
Use specular when you want a perfect dielectric material. It will render faster than a Glossy Transparent material. Specular materials have perfect reflection, glossy transparent materials do not.
rogal
Post by rogal » Fri Feb 22, 2008 2:56 am
hi! where can i find the fog switch? is it in the skindgo UI? or do i have to add it manually?
crojack
Post by crojack » Fri Feb 22, 2008 4:41 am
It's just turning on fog in Sketchup. Although i found by rendering an outdoor scene with fog that the sketchup fog controls don't correlate to where the fog is in the final render. I put the fog in sketchup way in the background, but in the render it was all the way to the camera.
rogal
Post by rogal » Fri Feb 22, 2008 8:05 am
I'M SUCH AN IDIOT :P never mind... -___________-"
crojack
Post by crojack » Fri Feb 22, 2008 11:28 am
don't worry about it. but note that i rendered my scene for days and days and it never really came clean.
