XSIndigo Exporter for SOFTIMAGE|XSI v.6.xx
Announcements, information, requests and support regarding other exporters and general/new exporters
5 posts • Page 1 of 1
rgigante
Post by rgigante » Wed Apr 16, 2008 10:13 pm
Good morning,
I'm glad to announce the availability of "XSIndigo Exporter" 1.0.9.1
The plug-in packaged in an XSI add-on ( for a fast and easy-to-install approach) is compliant with the last Indigo Renderer release (1.0.9 aka 1.0 Stable). It's available only for 6.xx major release
All Indigo Renderer features are today supported while also being supported subdivision surfaces (renderer/OGL mode), RenderTree (through the use of provided Indigo shaders) and Hierarchical Instancing.
To install the 1.0.9 update please remove the old one before installing the newer.
The archive containing the add-on is available in the following section of this site: Download -> Exporter 3D Apps -> Softimage|XSI or directly at the following link XSIndigo Exporter 1.0.9.1 - SOFTIMAGE|XSI 6.xx
Best regards, Riccardo.
Velazquez
Thanks a lot
Post by Velazquez » Sat Apr 19, 2008 7:33 am
Thank you very much. Your work is highly appreciated.
Best regards, Javier
Velazquez
Can't add Medium to specular material
Post by Velazquez » Sun May 04, 2008 1:19 am
Hello, see if you can help.
XSI 6.02
Indigo 1.0.9.3
I have a sphere and I assigned a IdigoMaterial.
When trying to edit the "Medium" the button doesn't do anything.
Exporter will give an error until the Medium is defined,but I can't
I will appreciate any help
Thanks for your work.
Javier
Velazquez
Oops
Post by Velazquez » Sun May 04, 2008 2:30 am
I forgot to specify:
the indigo materials with the buttons not working for me are the "Specular" and the "Glossy transpartent"
Am I missing something?
Thanks
Javier
rgigante
Post by rgigante » Wed May 07, 2008 3:52 am
Released XSIndigoExporter 1.0.9.1 fixing a small bug related to indigoMaterial node not working with Oren-Nayar shader.
See first post for the correct link.
I apologize for any inconvenience occurred.
