hi newly, this is my problem, please help me if you can:
when i export a scene with maya material all work fine, but when I put into the scene an indigo shader...this is the result:
in the output window: Error getting shader
in the script editor: Writing Materials...
// Error: No object matches name: indigoShader4.normalCamera //
select -r indigoShader4 ;
delete;
Why?
problem with indigo shader
Welcome puntotoprinici !
What Maya and MtI versions do you use ?
Well I have no immediate answer, I'd bet on a broken scene scenario... but broken indigoShader is a possible thing, though it has shown to be working here. I'm not qualified with python plugins
This error is unexpected... ah, was the plugin loaded ? Maybe you loaded a previously created scene when the py plugin was not available in paths (like after installing a new version of Maya) ?
Here an indigoShader has a normalCamera slot for bump by default, so I am a bit surprised...
puntotoprinci
puntotoprinci
1.0.9_3 is the latest stable exporter version, yes. I will make a package of the last registered version so you can reinstall everything and run the latest Indigo version, new features are currently in progress, a darn slow one
The error seems to be caused bu the shader plugin, not the exporting process. I guess your copy of the plugin is somehow corrupted or wrongly installed (you need to have python 2.4 installed on your system too), since it creates the indigoShader and it's atttributes, including normalCamera.
Expect a new package release this week-end, with no new features as of today, I'm messing with code for them... I managed to keep my local version running despite this work, and this is good news already
puntotoprinci
Ok, I'll have to precise it over and again: I was mostly a spectator of the creation of MtI, i've made like 5% of it only
The actual working things are due to Benedikt Kircher and, for the biggest and most recent part, Doug Hammond (I am Adam Penalver). I am learning mel with MtI atm, and python (indigoShader) is still out of my scope...
But I will be happy to make MtI progress, just I'm a hobbyist not a coder yet
