Cindigo 2.0.X progress
Re: Cindigo 2.0.X progress
Post by fused » Tue May 05, 2009 8:41 pm
zeitmeister wrote:ROFL! A nice scene, with 6 to 7 omnis as fill-lights, HDRI and sunsky... :D
so you dont like the it? :(
Post by pixie » Tue May 05, 2009 8:44 pm
What he doesn't have to like? :?:
Post by fused » Tue May 05, 2009 9:00 pm
pixie wrote:What he doesn't have to like? :?:
It just sounded like he does not like the light conversion stuff :)
Post by pixie » Tue May 05, 2009 9:14 pm
I think he's praising the light system :P
Post by zeitmeister » Tue May 05, 2009 11:10 pm
Sort of! ;-)
Honestly:
the light conversion does make very much sense, having in mind to see something in C4D what comes close to the idea of the expected result in Indigo.
Example: when I place just planes with an emitter material in my C4D-scene, I see nothing... in the C4D editor window.
If I could place area lights instead, which are being converted automatically to emittive planes when being exported to Indigo, I get a much better idea of what is happening in my scene in the C4D editor window.
So please please implement it! :-)
It will put Indigo and C4D visually much closer together.
Post by fused » Wed May 06, 2009 2:30 am
zeitmeister wrote:Sort of! ;-)
did it, nearly done with it.
tonight i will spend some time on the custom ies feature Zom-B suggested. its gonna be awesome :)
Post by pixie » Wed May 06, 2009 3:11 am
Don't forget my suggestions either :D
carsten_fokuspunkt
Post by carsten_fokuspunkt » Wed May 06, 2009 4:23 am
it sounds very promising fused!!!
hope, you got it tonight :)
looks like my license of indigo will be useful in future.
Post by fused » Wed May 06, 2009 11:51 am
pixie wrote:Don't forget my suggestions either :D
Of course not :)
here are some pictures with random c4d light tests, you will be able to contol them a bit more with a light tag, but this is not implemented yet (the very same light tag that was used for the meshlights back then).
the spotlights are using a default.igs for now, havent started coding the IES stuff.
Post by zeitmeister » Wed May 06, 2009 6:04 pm
Oh....
nicenicenice!
One question: do you always attach a light tag or a light normalisation tag to emitting meshes?
I never understood the difference completetly...
Post by fused » Wed May 06, 2009 6:33 pm
zeitmeister wrote:Oh....
nicenicenice!
the light normalization tag is only for emitting materials(you need to attatch it to an object and then set the material in the the tag to a material that should be scaled on the mesh), but its obsolte. i think i transfered the settings to the material helper, or not?
but wait, ur on a mac right? i think that might have been in RC4...
Post by pixie » Wed May 06, 2009 8:59 pm
nicenicenice!
Well... you could have the same light material applied in different objects and yet having each one a different strengh.
Well I can name yet again my suggestions:
- automatic setting of scale acccording to the cinema own settings
- chosing the scale where user wants to work (wether mm, cm, dm, m,...) according to the unit
- aknowledgment of the sun object/Sky(with background) automatically
- Global a) b) c) for each and every texture Albedo
- Global/Local a) b) c) applied also to the RGB colors
- removing the height/width from camera tag or create a different tag...
Post by fused » Wed May 06, 2009 9:04 pm
pixie wrote:Well... you could have the same light material applied in different objects and yet having each one a different strengh.
Yes, that is why i made the normalization tag in the first place, but it really is so very impractical that i decided making a new material everytime you want a different strenght should be better.
it also takes away some complexity. all settings in 1 object right where you need it.
Post by pixie » Wed May 06, 2009 9:12 pm
I like the normalization tag, it makes me feel important! :D Anyhow, if light tags are to return to the lights it will be the same I guess
Post by fused » Wed May 06, 2009 9:22 pm
pixie wrote:I like the normalization tag, it makes me feel important! :D Anyhow, if light tags are to return to the lights it will be the same I guess
Yes but note that in future versions you cannot use light tags on meshes, because mehlights are not supported by indigo anymore.
